Sts turbo replaced with oil less comp turbo
I'm thinking of replacing the standard 68mm with a comp either a 76mm or 80mm. My question has anybody done this with a sts kit. Are the turbos close outside physical? If not what needs to be changed? This will be going on 6.0 with ported 317 heads, ls6 intake,236/246
.601/.613,114+1 lobe separation cam and m6 trans.
I bought this roller with with turbo kit on , but I'd really like to get ride of some possible issues with running scavenger pump ect and I think I could benefit from larger turbo with the extra c.u., ported heads ect.
LS1Tech Sponsor
We are direct with Comp and can get you set-up with exactly what you are looking for. If you can provide some info, or photos/measurements of your current turbo we can get you one that will drop right into place, Oil-less, and provide much greater power potential as well! Shoot me some info over via e-mail to: huronspeedproducts@gmail.com and I would be more than happy to assist you!
Jon
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
