***biggest numbers out of twin s366's*** What's the best numbers that you know of on a balls to the walls pair of s366's? I'm putting a set on a 403ci LS2 and the motor can spin 7000rpm and see about 30psi. I think I could actually max these turbos out... but what have you guys seen to the wheels with these? Thanks in advance |
I saw a thread where a guy made like 737rwhp on 12psi on a 6 liter. I know several people have similar setups and I haven't seen one person throwing any boost at it |
I dont think your ls2 will hold that 30psi you plan on chucking at it unless you have oring gaskets. Im halfway through a similar build. Lq9 403ci 11.5:1 comp ls3 heads twin s366 and a powerglide. Plan on pushing 20-22 psi. Maybe more if it feels strong |
Best I've heard of is Chris' Silver S10 5.3 SBE 8.40'S |
Ive been using a pair of s366's for a few years now on my 5.3 Only dynod it once 14psi made 685whp I run 26psi at the track, and has pushed 3250 lbs to 161 mph. My combo is not an optimized race car. The fastest guy I know that used them was Seth temple, he works for bw air werks and ran low 5s at 140+ in the eighth. |
Originally Posted by S_M_I_D_D_Y
(Post 18460255)
I do. I do everything myself |
Originally Posted by Rob Carlson
(Post 18461082)
I plan to push 30psi on mine when builds done. 1200+rwhp I'm looking for thru th400. 6.0l or a iron 5.7. Not sure yet. On an ideal setup all working together they should be good to near 1500 on a 6.0 or less cube. |
Certainly do have a good tuner mate. Running it on e85. Plenty of very similar builds getting around in aus no worries at all :) |
(Post 18462065)
| All times are GMT -5. The time now is 10:34 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
