Timing curve (Built motors)
Old Dec 28, 2014 | 06:11 PM
denmah's Avatar
Moderator
on race gas 22psi 17deg did 174mph @ 3050lbs
Old Dec 28, 2014 | 06:15 PM
oscs's Avatar
Originally Posted by denmah
yeah i believe i ended up with 19psi 13deg and that went 8.32@164mph 924whp so i splashed one extra degree in there since it liked it.
Those are really good numbers. Hoping to lay down 900ish on pump
Old Dec 29, 2014 | 08:03 AM
yenkomike's Avatar
one thing to remember built motor or stock if it rattles hard enuff it will break just as easy.
Old Dec 29, 2014 | 08:25 AM
oscs's Avatar
Yeah I'm not looking to get terribly greedy with timing but I don't want to leave a bunch on the table either.
Old Dec 29, 2014 | 11:06 AM
stevieturbo's Avatar
was just going to post up my table and saw it already here haha and suggest starting lower also and checking results, these motors start dropping off power long before they start having issues with knock and etc, theyll talk you just gotta not be greedy and listen.
usually good rule of thumb 0psi 22deg, 14psi 14deg, and then start moving around from there, every combo starts to vary at 14+ psi i would say.
Why such low timing in the 100kpa area ? Or is that quite high compression ?
Surely it'd make a lot more power in the high 20's ?
Old Jan 1, 2015 | 05:47 PM
slowlsx's Avatar
when your leaving at 5+psi on the brake I don't think timing matters at 100kpa. maybe on the street transitioning from vacuum to boost but at that weight and that much power all its going to do is just spin more!
Old Jan 1, 2015 | 07:07 PM
THADD's Avatar
Timing makes power, it matters at all levels of boost.
Old Jan 1, 2015 | 07:13 PM
I think his point is...it's a drag car, it will never be down there anyway so it really doesnt matter whether it makes some more power there or not.
Old Jan 1, 2015 | 08:42 PM
THADD's Avatar
Yeah I guess I see what you are saying, sort of.
Old Jan 17, 2015 | 03:24 PM
Monte4ever's Avatar
Does a Procharger timing table work sort-of like a turbo's table as far as boost is concerned?
Old Feb 27, 2015 | 09:39 PM
BUDGETRAT's Avatar
IMO you should just have a **** for timing with zero numbers involved. Start out "low", slowly "turn it up" until it stops making power. Aiming for a specific number is pointless.
My 10:1 5.3 ran on the ragged edge around 17* and 25lbs. After about 10-15 runs at this level it eventually pushed the HG. This was E85, intercooled, and water/meth inj. as well.
You'll probably end up with something like Matts pump gas table below. I'd still start out lower.
Sorry for the dumb question but is the ignition load % on Matts table the map sensor kpa?
Old Feb 27, 2015 | 10:50 PM
  #32
oscs's Avatar
Yes it is
  #33
Forcefed86's Avatar
Yea anything over 100kpa is "boost".
Tree'd... didnt' refresh
Old Feb 28, 2015 | 12:44 AM
  #34
Blown06's Avatar
8 Second Truck Club
Does it work the same as in how you enter the numbers and ****: yes
Do you just want a copy of a turbo timing curve for a procharger: no
Do you wanna follow the same protocol in building your own timing map: yes
