1987 Grand National LS Swap with 76mm Turbo
A few months ago, I found this 87 GN in Alabama. The body was solid, but the paint was faded and the car hadn't been started in a few years. A few weeks later, I figured out why. The original V6 had a rod knock. I sold the car to a friend and we strategized on how to proceed. We decided an LS swap was in order.
He removed the engine and began cleaning the car. With a lot of elbow grease, the original paint actually turned out pretty decent!
He installed a mild Comp Cams custom grind cam, dual springs, and pushrods, on the SBE 5.3L. For now, it will have the ON 3 Performance 76/75.
Here are the specs at a glance.
FAST XFI 2.0 ECU.
TCI EZ-TCU
FAST 92 mm intake and TB
Walbro/FAST 450 lph fuel pump
FAST 306008 Injectors
Comp Cams custom grind 225/226 .612/.605 114+3 cam
Comp 850-16 Lifters
Comp 26925TS-Kit springs
Comp 7955-16 pushrods
Comp 7106 Timing set
Rebuilt 4L80E transmission
TCI 9.5" torque converter
ON3 Performance 76/75 turbo
CX Racing IC
Custom headers, cold side and hot side
Summit Racing radiator
It should be running in the next 2-3 weeks. The goal is to have a car that can be daily driven, get 20+ mpg, and run 10's at the track (and maybe down at Mexico as well. )
FAST XFI 2.0 ECU.
TCI EZ-TCU
Comp 850-16 Lifters
CX Racing IC
