Those running the Aster Bracket, let me know your pulley/belt lengths - Page 2 - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
Reload this Page >
Notices
Old 02-01-2016, 08:24 AM
95-1LE-Z28's Avatar
Anybody running a 4.0 pulley with the CBR 8.65 crank pulley? If so what belt length and what position is the idler. Thanks in advance.
95-1LE-Z28 is online now
Old 02-05-2016, 07:29 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
If you find out the info, please let me know. Thanks! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: [email protected]
https://www.brutespeed.com/index.htm Link to website
Bob@BruteSpeed is online now
Old 02-05-2016, 09:57 AM
95-1LE-Z28's Avatar
Certainly.
Old 02-07-2016, 07:48 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
That's a good question, because when I'm ready for some more power, that's going to be the route I go. I just need to get my fueling and intercooler sorted out first before I crank up the blower.
The Alchemist is offline
Old 05-14-2016, 06:13 AM
UNDER PRESSURE MOD
I'm just updating this with some new found knowledge. For a 7.65"/4.00" combo, with a Gates, green belt, 52.5" long, you need the idler in the position furthest from the blower. I have mine in the middle position, and I'm losing boost in the upper rpm range, and finally saw the dust on the bracket last night.
As the rpm's rise, and the tensioner takes up the slack, it will bottom out, and no longer be able to take up slack, so that is why the idler needs to be in the further position to allow the tensioner to take up the slack.
In a perfect world, we'd have belts that wouldn't stretch, but till then, we have the Aster bracket setup to take up the slack when they do.
Old 05-21-2016, 05:44 AM
LS1Tech Sponsor
Good info, thanks! Bob
__________________
Old 05-31-2016, 02:16 PM
95-1LE-Z28's Avatar
8.65 cank pulley/ 4.0 pulley - 53.7" long 8 rib belt
Old 05-31-2016, 02:24 PM
LS1Tech Sponsor
Thanks, I appreciate it! Bob
__________________
Old 12-01-2017, 12:20 PM
95-1LE-Z28's Avatar
4.13 pulley with 8.65 crank pulley - Gates K080537HD.
I think this belt might have been a bit too tight. I switched to K080545HD with the Idler in the middle hole and that seems to be perfect.
Old 12-01-2017, 12:36 PM
LS1Tech Sponsor
Thumbs up
Thanks for the info, I'll get it added. Bob
__________________
Old 12-05-2017, 11:20 AM
white01ss's Avatar
After blowing through another set of little pulley bearings in three months I decided to try an experiment.
I bypassed the little pulley by routing a shorter belt underneath it, basically doing SDCE style belt routing. Recently made 580 whp on a mustang dyno without meth with this new setup which puts me right at my no meth 650 whp dynojet dyno with the Aster 7.65/3.4 setup years ago. So it doesn't seem to be giving up much not running the little pulley.
Current setup:
52.5" Belt K080525HD. 8.65 CBR, 3.85" Blower, Idler on Far position, little pulley bypassed.
Previous setup:
53.7" Belt K080537HD. 8.65 CBR, 3.85" Blower, Idler on Middle position, with little pulley.
Max RPMS of the pulleys with 7.65 and 8.65 crank pulleys:
Large Idler Pulley 2.75" Diameter, C=8.64"
With 7.65" Crank Pulley: 24.03/8.64=2.78 @ 6500 engine RPM = 18,070 RPM
With 8.65" Crank Pulley: 27.17/8.64=3.15 @ 6500 engine RPM = 20,475 RPM
Small Idler Pulley 1.75" Diameter, C=5.50"
With 7.65" Crank Pulley: 24.03/5.50=4.37 @ 6500 engine RPM = 28,405 RPM
With 8.65" Crank Pulley: 27.17/5.50=4.94 @ 6500 engine RPM = 32,110 RPM
white01ss is offline
Old 12-07-2017, 07:55 AM
  #32
LS1Tech Sponsor
Thumbs up
Current setup:
Previous setup:
That is good info, thanks for posting it! Bob
__________________
Old 12-07-2017, 11:15 AM
  #33
UNDER PRESSURE MOD
Good info.
Is the 8.65" pulley still available?
Old 12-07-2017, 11:17 AM
  #34
LS1Tech Sponsor
Good info.
Yes it is, I even have one sitting on my desk right now.
http://shop.brutespeed.com/CBR-8RIB8...8RIB865PLY.htm
Thanks. Bob
__________________
Old 12-09-2017, 05:48 AM
  #35
UNDER PRESSURE MOD
Thanks. Bob
Good deal Bob.
I might pick it up this spring when I decide I need more power
Old 04-27-2018, 02:26 PM
  #36
Default Belt
Did this belt work out for you? Idler position?
Thanks
Z QQH 6 is offline
Old 04-27-2018, 03:54 PM
  #37
95-1LE-Z28's Avatar
Thanks
Yes. Idler was in the middle hole.
Quick Reply: Those running the Aster Bracket, let me know your pulley/belt lengths
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
