ProCharger C6 Stage 11 Direct Drive System
I'm sure we could come up with something. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I wouldn't think so due to all the testing ProCharger does. They have a Mustang chassis dyno that sees a lot of use. Thanks. Bob
__________________
In order to make the 8 rib work on 09-13, the water pump needs to change to an 08 or be modified. Bob
__________________
The tensioner/6rib isn't an issue on the alternator, it is the 4 rib driving it all. It slips on the jackshaft.
Best way to run a kit like this is to cog drive the jackshaft so it can't slip. AC belt is stock then, cog belt drives jackshaft, and 6 rib the PS/Alt. Then if you don't have ac you can remove that belt too. Plus no issue with slip or issues. I had way too many issues with the 4 rib belt slipping, causing the PS/Alternator to stop. With A/C on it was even worse.
Cogged direct drive setup
I should have pricing on this Monday. Bob
__________________
My 99 camaro ysi is mounted up top using the vette setup. I don't think an intake hat would fit there. Maybe something custom, but there isn't alot of room there. IMO an electric pump is the best way to go with this setup. I don't have a/c or p/s, so the belts are super short. I still debate the p/s though. I guess I will figure that out once it is all finished.
Ryan
Ryan
http://shop.brutespeed.com/ATI-1GQ30...I-07-13-C6.htm
http://shop.brutespeed.com/ATI-1GQ31...I-07-13-C6.htm
Here is the new Stage 11 System and Tuner Kit. Bob
__________________
I'm waiting pricing for just the parts. I'll get back to you asap. Thanks. Bob
__________________
#33
Not on the pricing for just the parts, I'm still waiting on pn#'s and cost. I do have the pricing for the complete systems. Thanks. Bob
__________________
#35
__________________
