welding stainless sch10 elbow to ls3 manifolds
I cut the flanges off of a set of ls3 Camaro manifolds and installed them forward facing on my 67 mustang build. I have searched all over the internet for a supplier that sells individual carbon steel 2.5" elbows and cannot find any for sale. Individual stainless fittings are more easily found.
what complications will I run into if I weld a stainless elbow to my manifold assuming I used a 309L mig wire and pre heat the manifold with a torch. will the stainless elbow fatigue over time form heat?
adding an elbow, then a V band will give me a perfect exhaust outlet level with the oil pan.
I am not sure what elbow you are looking for but I found all of my schedule 40 mild steel fittings at a local pipe retailer. Prices were great and I used a couple 2.5" 45's and a 90. One of the 45's I welded onto the end of a cutoff truck manifold. It was perfect.
Not to spark a debate here but I will share my personal experience miging 309l with C25 I had a hell of a time getting the welds to look decent. In fact I never did. I burned the pieces together and ground them afterwards. I did a bunch of searching and the more I read the more I am seeing this is fairly normal using that wire. I wish someone had told me that as I was pretty disappointed with the results and super frustrated while welding it.
The following users liked this post:
Homer_Simpson (03-05-2024)
thanks for the replies!
i happened to find carbon steel elbows on McMaster-Carr's website. i will get a few 2'' elbows and see what i can do.
since the manifolds point downward at a 90* angle i was going to weld another 90* elbow to them so i can have forward facing v band outlets that will sit just about even with the oil pan. I will mount the turbo on the passenger side of the car and run a cross over from the drivers side past the balancer and up into the turbo.
I bought some 2.5 long radius mild steel elbows from a local pipe supply. cant beat $7 each! i also ordered some mild steel 2.5 v bands and miged my manifolds today with .035 wire and a heavy heat setting. My dad and i preheated everything with a torch. Here are the results.
i can also run the manifolds the other way and they will clear the stock steering box.
BTW, this is in a 67 mustang with the stock steering setup!
