Notices
another 69 camaro jy 5.3 turbo build
Old 03-02-2015, 09:45 AM
Yeah I'm running the corvette accessory drive. I should be starting a build thread soon.
gsxrred1000 is offline
Old 03-02-2015, 12:00 PM
6669camaro's Avatar
Got the intercooler mounted up this morning. Just barley fit. Gonna have to modify the bumper bracket in order to get the charge pipes in there. Only have about 1/2" of clearance between the hood latch on top and 1/2" between lower valence on the bottom.
I don't want to buy i may have to remove the lower driving lights to get some more air flow to the intercooler.
6669camaro is offline
Old 03-02-2015, 12:05 PM
6669camaro's Avatar
Cool. I'll be following along with you. It's always interesting to see how many different ways there are to skin a cat or turbo a 69 camaro! Lol!
Old 03-02-2015, 05:08 PM
Looking good. What dimensions is your intercooler and piping? Do you have a link to it? I'm debating 3" or 4" intercooler. Don't really want a big restriction. I'm also running water/meth so not really worried about air inlet temps with just intercooler.
Old 03-02-2015, 05:30 PM
6669camaro's Avatar
It's the treadstone intercooler rated for 1000hp
. I'm having trouble trying to get the link to it. I got it off of eBay. It's 3" inlet and out let. It's as big as you could fit in there hight wise with out getting rid of the hood latch.
Old 03-07-2015, 06:21 PM
6669camaro's Avatar
Got the down pipe all done today. Still need merge it into the 2.5" exhaust that's already on the car.
Old 03-08-2015, 08:25 PM
Was fitting up my intercooler today and man it's tight with a 4" core. Started cutting rad support lip off. How much room do you have behind your driving lights wires are right there. I'm thinking about wacking the whole bottom half of rad. Support off. And maybe supporting it with a tubular piece after intercooler is in. It would be so much easier and have a hell of alot more air flow without the damn hood latch. Lol
Old 03-09-2015, 07:40 AM
6669camaro's Avatar
I had to remove the wiring and bulbs to get it to clear. I thought about removing the driving lights also to help get air flow through it. I hear ya on the hood latch!!!lol I wish I just had a fiberglass hood and some nice zues fasteners!! I'm running e85 so I'm not overly concerned about high intake temps So I'll probably just run it as is for now and see how it performs on the dyno. I'm following your build too and it looks real good so far!! When are you thinking you'll have yours up and running?
Old 03-09-2015, 11:29 AM
Hoping for April. Most likely end of April. Lol alot to do in that time. I might try to modify the light sockets to 90 degrees. Somehow.
Old 03-09-2015, 12:15 PM
Think I found our parking light cure.
http://www.ss396.com/camaro/DT-2100169.html
Old 03-10-2015, 12:36 PM
6669camaro's Avatar
Finished up the merge pipe this am. Goes from 4" to 2.5" through a couple of knock off flowmasters that were already on the car. Couldn't be happier with the way it laid out. Really fits well under there.
Old 03-11-2015, 10:00 AM
  #32
Looks great. I'm just running a 4" dump behind pass. Front tire and eventually will run it back into flow master exhaust with dumps. I'm thinking about leaving the 4" dump with an electric cut out when I want it noisy tho. Great progress so far tho.
Old 03-11-2015, 12:47 PM
  #33
6669camaro's Avatar
I was actually going to do the same thing but with the wheels and tires I have now it would deff hit making a right turn , im going to get diff wheels and tires so hopefully it will clear with those! Your build looks real good so far. I'm also shooting for April, may to have this thing out on the road, still seems like there is a mountain of work left though!!
Old 03-15-2015, 05:27 PM
  #34
6669camaro's Avatar
Got all of the intercooler piping done. Also welded a dump on to the down pipe. The motor is ready to come back out to get the new oil pan installed and make mounts for the coil packs.
Also got the fuel cell and pump mounted today also.
Old 03-21-2015, 07:33 PM
  #35
6669camaro's Avatar
Made some more progress. pulled the motor, installed the Holley oil pan, drill and taped the oil return and feed for the turbo, power washed the engine compartment, welded a dump in the down pipe, welded in bungs for o2 sensor, sprayed on some dht exhaust paint then wrapped the cross over pipe. Started putting everything back together for the final time now!!
Old 03-22-2015, 03:23 PM
  #36
DCx
awesome build man. hope my pipes come out as clean as yours on my mustang build.
DCx is offline
Old 03-22-2015, 05:23 PM
  #37
DHR Darren's Avatar
Looks good!
If you think you have a tight fit, try twins in a Chevy II with a 3.5 gallon cell up front and a radiator while keeping the stock flat hood & latch!!
DHR Darren is offline
Old 03-22-2015, 06:07 PM
  #38
6669camaro's Avatar
Originally Posted by DHR Darren View Post
Looks good!
I can only imagine!!! I bet you had to cut the hell out those shock towers!!!
Old 03-22-2015, 06:14 PM
  #39
6669camaro's Avatar
Got the harness cut down today. Also made a new power steering hose.
Before
After. Most the zip ties are temporary.
Also wrapped and set in the down pipe. Just waiting on the flange gasket so i can bolt up the turbo.
Old 03-22-2015, 08:37 PM
  #40
Looking real good.
Quick Reply: another 69 camaro jy 5.3 turbo build
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
