Notices
another 69 camaro jy 5.3 turbo build
Old 03-22-2015, 09:12 PM
  #41
DHR Darren's Avatar
Originally Posted by 6669camaro View Post
I can only imagine!!! I bet you had to cut the hell out those shock towers!!!
I put a Smith Racecraft clip in it, that was a win win for the build for sure.
DHR Darren is offline
Old 03-22-2015, 09:29 PM
  #42
6669camaro's Avatar
Right on. Do you have a build thread started for it?
6669camaro is offline
Old 03-22-2015, 09:30 PM
  #43
6669camaro's Avatar
Originally Posted by gsxrred1000 View Post
Looking real good.
Thanks!!! Any new progress on yours???
Old 03-22-2015, 10:40 PM
  #44
DHR Darren's Avatar
Not on tech but on Yellowbullet.
http://www.yellowbullet.com/forum/sh....php?t=1073602
Old 03-23-2015, 11:14 AM
  #45
Ill be updating build thread probly tonite.
gsxrred1000 is offline
Old 03-24-2015, 03:15 PM
  #46
6669camaro's Avatar
A few more pics of the turbo and down pipe finished and installed for the last time. also a pic of the dump on the down pipe installed.
Got some new rubber for the camaro too. U unfortunately it's going to be 6 weeks before I'll get the new champion rims.
Old 03-24-2015, 03:47 PM
  #47
Blazin24's Avatar
Default Another 69 Camaro build here...
Glad to see other builds like mine in current process!
I've been working on my '69 Camaro 5.3L turbo build for a while now myself. Its funny to see others running into the same issues that I am with keeping the factory hood latch and running the FMIC. Here is a pic of the current state of my build. I'm in the process of pulling the motor back out so I can send to paint in a little over a week! Keep the build pics coming, loving what I'm seeing.
Blazin24 is offline
Old 03-24-2015, 03:55 PM
  #48
6669camaro's Avatar
Looks real good! It's always interesting and sometimes very helpful to see other versions of the a build! What are some of the specs of your build???
Old 03-24-2015, 04:15 PM
  #49
Blazin24's Avatar
2005 5.3L block, cleaned up at the machine shop
New bearings and rings gapped for boost.
ARP rod bolts and head studs.
LS9 headgaskets
Z06 cam and springs
LS1 heads and intake with 80mm TB
New Garret .81 A/R Turbo
Junkyard 4L80/converter
I'm basically using a bunch of stuff that I had laying around from other builds and putting it together into my 69 that I picked up a little over a year ago and a pile of rust (literally)! Only factory parts left on 69 body are the A-pillars, roof and inner rear structure. The rest has been replaced.
DSE mini tubs with TCI Torque arm rear suspension.
Currently sitting on C6 wheels 18"/19" combo.
Here is the original body:
Blazin24 is offline
Old 03-25-2015, 12:23 PM
  #50
Cool build
Twinstang is offline
Old 03-25-2015, 01:37 PM
  #51
Looks great so far. What are your plans for the heater hose outlets on the waterpump? I built my hotside similar to yours and cut the nipples off the waterpump. I was planning on tapping threads and just plugging them. I know a lot of people say you need to loop them but its just not an option due to space/heat
Madmike6.0 is offline
Old 03-25-2015, 02:44 PM
  #52
6669camaro's Avatar
I just removed the nipples, tapped the holes and put a pipe plug in one and a temp sender for the cooling fans in the other hole. I did the same thing on the 5.3 in my coupe and it has had no effect on the cooling ability of the system at all. There really isn't and reason to loop them and its a lot cleaner look with out them there.
Old 03-28-2015, 06:42 PM
  #53
6669camaro's Avatar
Got a good start on the fuel system today. had to do some major modifications to the fuel rails to get them your accepted the 8orb fittings. They were supposed to come threaded fit 8orb but they had some odd ball thread pitch with a copper gasket. Ended up drilling and tapping them to accept 8 orb. Was kinda a pain but it's done now. Just crossing my fingers that they don't leak!!! Lol!!
Old 03-28-2015, 08:58 PM
  #54
DHR Darren's Avatar
Better get that regulator off of the firewall, it is illegal.
If you have someone close that can TIG, have them pull the orings from the fittings and weld them directly to the fuel rails. It will eliminate any chance of leaks and a headache from one.
Old 03-28-2015, 09:22 PM
  #55
6669camaro's Avatar
Thanks for the info!! I'll just make a bracket for it off the back of the head. I can tig weld them at work but I think they will seal up.
Old 03-28-2015, 10:05 PM
  #56
Looks good do you happen to have a link to that intercooler I like it a lot. Also what engine mounts did you use ?
Old 03-29-2015, 07:55 AM
  #57
6669camaro's Avatar
Thanks! The motor mounts are energy suspension sbc engine mounts and sone universal lsx to sbc motor plates that I got off of eBay for like $30. The intercooler is a treadstone 1000hp.
Here's the link to the intercooler.http://www.treadstoneperformance.com...cooler++1000HP
Old 03-29-2015, 07:02 PM
  #58
DHR Darren's Avatar
Just hate to see ya get turned away for not being legal.
For future reference fuel lines & regulators must be a minimum of 6" from the firewall.
Old 03-29-2015, 07:39 PM
  #59
6669camaro's Avatar
I appreciate it!! Ive drag raced for almost 20 years but I always had my regulator mounted to the front motor plate just because it was the easiest place to put it. Lol! Never knew the rule but it sure does make sense now that I think about it.
Old 03-30-2015, 12:33 PM
  #60
6669camaro's Avatar
Fixed the problem with the locating. Your a wealth of knowledge!!! Also I checked out your build on yb. That is one bad *** Chevy II build!!!
Quick Reply: another 69 camaro jy 5.3 turbo build
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
