Notices
another 69 camaro jy 5.3 turbo build
Old 03-30-2015, 05:59 PM
  #61
DHR Darren's Avatar
Originally Posted by 6669camaro View Post
Fixed the problem with the locating. Your a wealth of knowledge!!! Also I checked out your build on yb. That is one bad *** Chevy II build!!!
Good work!
I had a bbc/no2 70 nova with a nearly identical bracket. Easy & it works!
Thanks for the compliments!
DHR Darren is offline
Old 03-31-2015, 11:39 PM
  #62
6669camaro's Avatar
Got the power distribution center all made up. it will power the coil packs, injectors, pcm ignition power, com coconstant power, cooling fan 1 and cooling fan 2.
6669camaro is offline
Old 03-31-2015, 11:48 PM
  #63
DHR Darren's Avatar
Nice work!
Old 04-10-2015, 12:44 PM
  #64
6669camaro's Avatar
Fuel system is all done now. All of the wiring is done with the exception of wiring in the cooling fans. Battery is relocated to the trunk. Just got a few more small thumbs to to and it should be up and running by the end of the weekend.
I left the positive cable extra long so that i can add in th master kill switch later.
Old 04-10-2015, 09:58 PM
  #65
DHR Darren's Avatar
Very cool!
Congrats on all the hard work and have fun!
Old 04-10-2015, 11:28 PM
  #66
6669camaro's Avatar
Originally Posted by DHR Darren View Post
Very cool!
Thanks! Should be running by the end of the weekend but not on the road just yet. Still need to install the 9" rear diff, caltracs, shifter and take it up to the dyno shop and finish the tune. And my New wheels won't be here till beginning of May.
Old 04-23-2015, 10:13 PM
  #67
6669camaro's Avatar
I have been working on the car just haven't posted any updates in a little bit. After I got the thing filled with antifreeze I noticed that both head gaskets were leaking coolant! Turns out my heads have the "notch" in them and won't seal up with mls gaskets. Pulled them off and bought a set of newer heads and threw them on there. Problem solved!!! I've had the car running but it doesn't run well, it's extremely rich. Probably just gonna take it to the dyno and have my tuner get everything nailed down from there on the tune. I got the 9" installed, just have to plumb the brakes and finish installing the caltracs. Went with a full spool, 3.50 gears and 35 spline axles.
Old 05-12-2015, 11:23 AM
  #68
6669camaro's Avatar
Got my new champion wheels yesterday. Had to do a little clearanceing on the back but after that they fit great. Car is pretty much finished up just waiting to get it to the dyno to get it tuned. Soonest I could get it in to the dyno shop was the 26th of may. Just been double checking everything I did trying to make sure I crossed all of my t's and dotted all of my i's! I'll post some numbers once I have them.
Old 05-13-2015, 01:10 PM
  #69
That's a sexy stance man, car looks mean for sure.
IronBlocked is offline
Old 05-13-2015, 05:13 PM
  #70
LSChevelle's Avatar
Nice job!!
Everything looks great, you have awesome fab skills!
Just as a heads up I notice a huge difference in spool/overall power when I have my exhaust open vs. closed. Same setup as yours, 4" downpipe connects into dual 2.5" with chambered mufflers. I have a 4" electric cutout right under the passengers seat.
LSChevelle is offline
Old 05-13-2015, 06:58 PM
  #71
6669camaro's Avatar
Originally Posted by LSChevelle View Post
Nice job!!
Thanks!! I've Got a dump welded into the down pipe so I'll Probably leave it uncapped most of the time unless it starts to gas me out or the sound is to annoying.
Old 05-22-2015, 09:09 AM
  #72
toxic99's Avatar
Very nice job man! Can't wait to see some numbers out of her. ESP track numbers 😉.
toxic99 is offline
Old 05-22-2015, 12:29 PM
  #73
Great job! This is inspiration for me to actually get out and work on my car
VintageCamaroChris is offline
Old 05-22-2015, 06:59 PM
  #74
6669camaro's Avatar
Thanks!! As long as everything goes good at the dyno on Tuesday I'm gonna start putting the cage in it as soon as I get it home! I'm really hoping I can get this thing into the high 5s in the eighth. That Will make it some what competitive in the street car classes around this area, if not then I guess I'll bee building the 6.0 I've got sitting next to it and be shooting for 1000rwhp! One way or another I'm gonna make to make this thing fast!!! Lol!!
Old 05-22-2015, 07:02 PM
  #75
6669camaro's Avatar
Thanks!!! This site is full of a lot of great inspiration!!! It's Got me trying too talk my buddy into doing a ls twin turbo swap into a Porsche now!!lol. It'll be nice to spend someone else's 💰 for A change!!
Old 05-26-2015, 02:57 PM
  #76
6669camaro's Avatar
The numbers are in from the dyno. Put down 704whp and 606wtq at 14.7psi. Was blowing through the converter pretty bad and maxed out the fic 1000cc injectors on e85. Pretty Happy with the numbers now I can't wait to get it to the track, shake it down and see what it can do!!
Old 05-26-2015, 09:33 PM
  #77
Very nice. Power numbers are good at that psi. I've been lacking on my updates and after all the late nights in garage I got mine running and was tuning on street at 5psi and spun rod bearing. So now I'm building a forged 5.3. Car looks great.
gsxrred1000 is offline
Old 05-27-2015, 07:30 AM
  #78
6669camaro's Avatar
Uhg!! That sucks!! What are you using for rods and pistons?? I've got a 6.0 sitting on the floor of the shop thats going to get built to replace the 5.3.....eventually. I'll be shooting for over 1000whp. For now I'm just gonna try to get used to this thing, took a couple of short drives and it's a monster!!!
Old 05-27-2015, 01:13 PM
  #79
rryan5429's Avatar
Default Camaro
Looks good man! Saw pictures of it yesterday on the dyno. Pretty good numbers for sure. Just about finished up with my 6.0 s475 cutlass (e-85). Hoping about two weeks. Then would like to get it down to Joey and hope it makes similar numbers. What year 5.3 did you use? Curious if it had the floating pin rods. I might have missed it in here if it was mentioned.
Rick
rryan5429 is offline
Old 05-27-2015, 05:05 PM
  #80
6669camaro's Avatar
Rick
Thanks! It's a 2000 5.3. your tune is deff going to be in good hands, Joey is one if the best tuners out there. Plan ahead though, he's booked out on the dyno over a month!!!
Quick Reply: another 69 camaro jy 5.3 turbo build
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
