Notices
another 69 camaro jy 5.3 turbo build
Old 05-27-2015, 05:07 PM
  #81
rryan5429's Avatar
Default dyno
Yeah. Had a friend down there a couple weeks ago and said about a month out. He really does seem to be on top of them for sure. Thanks for the info. Would love to check the Camaro out if you ever make it to Thunder Valley in Marion with it.
Rick
rryan5429 is offline
Old 05-27-2015, 06:08 PM
  #82
6669camaro's Avatar
Rick
I'll deff have it up there some time, my brother and another good friend of mine race there from time to time, plus the guy I sold my race car to to build this one races it up there also. Need to Put a cage in it first though.
6669camaro is offline
Old 12-08-2015, 04:21 PM
  #83
6D9
What acc drive are you running? Came out sweet.
6D9 is offline
Old 12-09-2015, 10:58 AM
  #84
rryan5429's Avatar
Did you get the cage put in it yet and did you ever get a chance to run it this year? Had some issues with mine first go around at Joey's (mechanical) got them sorted out and went back down and made 797 @ 16.5. I was very happy with that.
Rick
Old 12-09-2015, 11:51 AM
  #85
Originally Posted by 6669camaro View Post
Got my new champion wheels yesterday. Had to do a little clearanceing on the back but after that they fit great. Car is pretty much finished up just waiting to get it to the dyno to get it tuned. Soonest I could get it in to the dyno shop was the 26th of may. Just been double checking everything I did trying to make sure I crossed all of my t's and dotted all of my i's! I'll post some numbers once I have them.
Love the wheels what back spacing did you have to get for the rear? I have a 69 also and need to order wheels from champion.is you're car mini tubbed?
cstrohpaul is offline
Old 12-09-2015, 02:29 PM
  #86
6669camaro's Avatar
No mini tub. The rear wheels are 15x10 with 5.5 inches of back spacing. Had to beat the inside of the wheel housing and trim the lip of the quarter a tiny bit to get them to clear.
Old 12-09-2015, 02:31 PM
  #87
6669camaro's Avatar
2000 Silverado 5.3 stock accessories.
Old 12-09-2015, 04:05 PM
  #88
6669camaro's Avatar
Rick
Yup I just finished up building a 10 point 8.50 cert cage. I also pulled out the 5.3 and put in a ls1 stroked to 383 and stepped up to a s480.
Old 12-09-2015, 04:36 PM
  #89
rryan5429's Avatar
Nice! Looks good.
Just finished updating mine to an 8.50 cage. Only got to make three runs with mine this season. Did manage a 9.71 leaving with the footbrake and no boost shutting down a little early. Only had a 1.56 60'. Hoping with the cage and got the trans brake hooked up now maybe we can get some low 9 runs out of it. Hopefully we can both make it to Marion at some point next season. Yours should run damn good now!
Rick
Old 12-09-2015, 05:42 PM
  #90
What size inercooler and do you have pics of how you ran the cold side tubing under the radiator support? Love the car
Old 12-09-2015, 06:46 PM
  #91
6669camaro's Avatar
[QUOTE=rryan5429;19069545]Nice! Looks good.
That's hauling *** man! I made a couple of short passes on the 1/8 mile track with the 5.3 and shut down early but it was on track to run a mid to high 9. I will deff be at the king of the streets race in August. In gonna try to make it up there a couple of other times too.
Old 12-09-2015, 06:48 PM
  #92
6669camaro's Avatar
It's the treadstone one that is rated for 1000hp. I don't have any pics of that piping but I did have to remove the main bumper brackets off of the frame to get it to clear the piping.
Old 12-09-2015, 06:49 PM
  #93
6669camaro's Avatar
New motor put down 962whp at Joe's
Old 12-09-2015, 07:26 PM
  #94
rryan5429's Avatar
Man that's good power. I'm hoping to make it down for the king of the street race. I should be down a couple other times for the stock and super stock races there.
Old 12-09-2015, 08:35 PM
  #95
Damn. 962whp. Big upgrade from 5.3. Lol how's that s480 spool with the 383 ? Also what psi was 962?
gsxrred1000 is offline
Old 12-09-2015, 09:48 PM
  #96
6669camaro's Avatar
It spools pretty quick, maybe a second of lag, About the same as the s475. Made 962 at 23psi. It's a stock housing, cast wheel s480, also put in a ptc converter. Gonna race it pretty heavy this next summer if every thing holds up. Next winter I'll add a race cover and billet wheel to the turbo and a custom ground cam for my combo, shoot for 1000whp at 20psi.
Old 12-10-2015, 10:09 PM
  #97
6D9
Thanks!
6D9 is offline
Old 12-15-2015, 01:20 AM
  #98
Awesome wheel and tire choice! Sweet build
LanceL is offline
Old 12-15-2015, 07:30 AM
  #99
6669camaro's Avatar
Thanks! Switching to the aluminium block ls1 took about 80 lbs off of the front end so it's sitting a little to high now. I'm putting qa1 coil overs and tubular control arms on the front and will lower it by an inch or two, also got a set of afco eliminator double adjustable shocks for the rear to help plant the drag radials.
Quick Reply: another 69 camaro jy 5.3 turbo build
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
