Wastegate Placement Question Single Or Change to Dual?
Old 03-03-2015, 07:46 AM
lower_the_dynamite's Avatar
Default Wastegate Placement Question Single Or Change to Dual?
Follow up question. Since I'm going to an SD tune, could I add a second 38mm gate, use the locations for the 02 sensors and weld the that wastegate flanges there? Any issues mounting the gate in the upright position or should I do a sharp angle towards the flow of the exhaust? I could cut and block off the flange location currently. From the pics of it on the old set up, I would have plenty of room(close on the waterpump) I planned on doing 2 O2 bungs on the exhaust when it's made (front bumper). Pics below.
Old 03-03-2015, 09:44 AM
oscs's Avatar
IMO with that turbo and that gate placement you have an under sized wastegate. I would feel a lot better with a 44mm gate.
Old 03-03-2015, 10:02 AM
mrstepheneades's Avatar
This is a hotside of aluminized steel I just did for a friend. Its independent tubes so I had to jump off of each and merge again together for the wastegate. I tried to make it flowing it the direction of the exhaust where the gate tubes come off the main ones. Its a street car and this is a JGS 40mm wastegate with a s475 turbo.
IMO 2 wastegates is the best way but in this case my friend didn't wanna pay for two.
On your combo like already stated I think you need a 44-50mm gate to control boost. 38mm is petty small. This 40mm on this car is pretty small but will do for this particular setup.
Old 03-03-2015, 11:58 AM
oscs's Avatar
Originally Posted by mrstepheneades
This is a hotside of aluminized steel I just did for a friend. Its independent tubes so I had to jump off of each and merge again together for the wastegate. I tried to make it flowing it the direction of the exhaust where the gate tubes come off the main ones. Its a street car and this is a JGS 40mm wastegate with a s475 turbo. IMO 2 wastegates is the best way but in this case my friend didn't wanna pay for two. On your combo like already stated I think you need a 44-50mm gate to control boost. 38mm is petty small. This 40mm on this car is pretty small but will do for this particular setup.
Pretty clever placement, flows nicely.
Old 03-03-2015, 12:51 PM
It's hell to weld in some spots lol. Just tried to get the flow directed right off the main tubes.
Old 03-03-2015, 02:05 PM
Ryans99ls1's Avatar
Its not optimal but it will work if you dont want to run really low boost. I have mine mounted the same way, controls fine but mine is a JGS 50mm. I would see if you can get something larger than a 38mm if you are keeping it mounted there.
Old 03-03-2015, 02:55 PM
Thanks everyone. Looks like I'll go with a bigger single gate.
Old 03-04-2015, 07:37 AM
MUSTANGBRKR02's Avatar
Usually don't want a gate facing down. Condensation can pool there and corrode the gate.
Old 03-04-2015, 08:26 AM
Sarg's Avatar
Or just add a second 38. My 5.3 s480 had one of the 2 38s stick and boost in high gear or load would go over 20 with a 10 psi spring. With the second gate it sits right at 10 psi. If you are keeping the pipe divided a 2nd gate is optimal and if you decide to upgrade to a larger divided turbo in the future you will be set. (Also quickened spool keeping it divided)
Old 03-06-2015, 08:43 AM
ezstriper's Avatar
the location shown in your pic will not work well at all unless you have a lot of back pressure going into turbo(which you should not) really need two split off manifolds, we had the same looking setup and would not work at all..
Old 04-01-2015, 08:32 AM
Updated post #1 with follow up info.
Old 04-02-2015, 02:21 PM
Any help would be greatly appreciated!
Old 04-03-2015, 12:07 PM
TRIXLSXSUPRA's Avatar
WG placement would be best with the flow of the gasses w/o a hard turn or going the other direction for that matter even if you're most concerned about controlling the WG so depending upon your target boost levels you can run a small gate but you may get creep and only be able to run a low boost setting that is higher than you'd like.
I've had to run the WG off a manifold before that was almost 90* due to space restrcitions and it def/ made a difference when going from a 38mm Tial to a 46mm PTE WG obvioudly but it still worked ok for what i needed
Old 04-03-2015, 12:29 PM
93camaro_zzz's Avatar
To answer your question, and if I were you, I would take off the crossover, and modify it to add another 38mm wastegate. Here is a crossover that I helped design and build with a buddy of mine. His car has rock solid boost control, and I think the whole thing looks sweet. I am just jealous that his crossover is actually better than the one on my own vehicle. haha
Old 04-08-2015, 08:17 PM
MM98's Avatar
Im space limited using a 60mm gate for my S475. Would this location be ok to control a 12lb spring? Thanks!
Attached Thumbnails Wastegate Placement Question Single Or Change to Dual?-20150408_200855.jpg
Old 04-08-2015, 08:24 PM
Sarg's Avatar
What size gate?
Old 04-08-2015, 08:27 PM
MM98's Avatar
Originally Posted by Sarg
What size gate?
if you're asking me, it's a 60mm gate
Old 04-08-2015, 09:17 PM
Sarg's Avatar
Yeah with a 60 I am sure you will be fine depending on the turbo and the motor. Now if you are doing a t3 turbo on a 6.0 motor you might have some issues, haha.
Old 04-09-2015, 07:58 AM
SwampWS6's Avatar
Originally Posted by Ryans99ls1
Its not optimal but it will work if you dont want to run really low boost..
What are you calling low boost? I have a 44mm gate for my S480 with a 8lb spring. Just wondering if it was adequate enough.
Quick Reply: Wastegate Placement Question Single Or Change to Dual?
