Should I open the ring gaps on a non intercooled E85 turbo 5.3L?
I am building a front mount 5.3L in a S10. The turbo is an On3 78/75 and I want to run E85 non intercooled. Looking to run 12-15#'s. Just wanted to ask some guys with experience if it would be worth opening the ring gaps. I know E85 cools the combustion temps, but running without an intercooler I could see air in temps between 2-300°F. Open to suggestions as to what you have seen work....
What are your current gaps at? If you don't know, I'd check them. I've seen as tight as .016 which I would say is too tight for FI... Esp without an IC. .005-.006 X bore is the standard for top rings and fine IMO. I'd error on the wider side with hot air stuff. (which I have zero experience with) Several of the successful hot air combo guys are pretty tight lipped about their setups. Maybe one will chime in.
The consensus is to leave them alone if the engine has some miles on it (100K+). Less than that you should check. My 77k mike LQ9 was something like .015-.016 on some cylinders. I opened them to .024 and one by mistake to .026, which I shoved into the "problem cyl" #7. No blow-by or ANY oil in the catch cans!
I'd open yours to were Forcefed suggests.
Thanks I am going to open them to .20-.22. I am still debating whether to run an intercooler or not. I want to be in the 600 rwhp range give or take. Its pretty tight on the front end of these S trucks, although I have seen a few people make it work. I've seen guys cut the bumper frame horns, which I didn't want to do being that this is more of a daily driver build and I want to keep as many safety features as possible.
I ended up with a 31x12x3 intercooler from a buddy of mines. The outlets were front facing which actually work out in this case. I was about to use to old core support for mock up and fit the intercooler in it with the radiator in the stock location. I plan to get the outlets shortened but thats about all i should need to do. With some 90° couplers it should wrap around and go through the core support under the headlights.
