how much power would you push a stock lq9 crank
Restricted User
Depends. With a turbo they seem to last 1300 or so flywheel HP (although there have been a few pushed to 1300 or so at the wheels). With a blower, less, since the belt is usually causing the crank to flex slightly.
Sounds pretty similar to some local guys here
5.2 and 5.3 at 138ish
Somewhere around 1100 wheel, without an issue
I think it depends on the setup and tune as well
A stick car dropping the hammer off a 2 step will probably make a little more load to the crank than an auto car would
I wouldn't think twice about using one above 1000 wheel
9 Second Truck Club
I just pulled my engine down to inspect and do pistons and rods. Was afraid to push it a 4th season lol. Crank actually passed a wet mag test and seems to be fine. Im still debating on if Im going to keep using it or step up to a K1 forged crank that I have here.
This is a great topic as i was just debating on going aftermarket stroker crank, or keep the stock crank.
For some reason the wiseco pistons i was looking at get more expensive for the pistons for a 4" stroke crank, not sure why.
Anyway is there anything special you do to make these stock cranks live at this power? Obviously balance them to the forged rods and pistons. Then I'd assume run ARP main studs, ARP 2000 rod bolts. Anything else?
Restricted User
You could always send your crank out to Castillo in Cali and have it nitride treated.
4" stroke pistons are more expensive because they are a complete re-design. The pin height has to be changed so that you don't have to run really short rods on a 4" stroke to keep the pistons from hitting the heads.
I haven't seen one of the wiesco LS pistons. Have used wiesco's in lots of other applications with great success. I'm leaning toward using stock crank, with forged rods and pistons. Seems like a great option for strength and longevity.
Watch now, I'll drive over my crank next weekend at Shady Side just for talking junk...lol.
BTW GPR, our 4" stroke Wiseco's are the same price as our 3.622" Wiseco's. Call for pricing if you'd like.
9 Second Truck Club
I say we keep proving the experts wrong that tell you that a stock crank won't last past 1000hp.
Originally Posted by Torqueshaft
Seems I remember it saying it was somewhere in the low 30's...
