What turbos for 441 LSX?
This will be my first FI build, going in my personal stock frame prerunner...
Current Parts-
lsx tall deck block (will be 0 decked to about 9.3)
Callies Magnum XL crank 4.125" stroke
Callies Ultra I-beam rods
ARP head and Main Studs
Billet main caps
Diamond Pistons 4.125 bore 25.3cc dish 1.115 comp height
Still havent decided on heads or cam yet.
I also have 2 water/air intercoolers and dual 75mm throttle bodies to make custom cross ram intake.
I'm looking for around 900-950hp reliably with a flat torque curve to 7000rpm. What dual turbos would you recommend for fast spool at lower rpm and still have enough flow at the top end?
How much boost?
I also know nothing about different EFI controllers, I always just go stock or carbureted. Any Recommendations?
If you're cammed right, and have everything else setup optimal I would say something in the 62mm range, I'm partial to Precision, but Garrett, Borg, etc. are all great companies.
Really, with that kind of shortblock, I would put twin PTE 6870's on it, and let it eat. But I'm not sure if you have certain class restrictions, or if it's just a fun truck.
Will easily make your power & tq goals and a lot left on the table.
I built 454ci LSX Tall Deck for a friend's C6ZO6 with PTE 6766s turbos made 1054rwhp 1085rwtq on 15-16psi straight 93 pump gas spools very hard and pulls all the way to 7100rpm we're hoping for 1400+rwhp on 26-28psi
Or you can check the Borg Warner turbos if you have some room in the engine bay great price and will make the power you're looking for.
As for EFI, the Holley is popular.
Or for a new install and they claim almost no tuning required, there is Pro-M EFI
My wallet isn't really deep enough to do a rebuild every few runs, so I want it to last a few thousand hours of mid to wide open throttle.
It will be mated to the GM TH400 Auto 3 Speed to handle the abuse of rock and desert driving.
Still looking for a set of 6 bolt heads to match my build and I'll figure out the cam after I get the heads and turbos figured out.
Also willing to run race/pump mix but prefer to make those numbers on 91 octane.
I'll be all over rocks and bumpy roads at breakneck speeds, and a lot of WOT.
Will these hold up to the abuse and heat?
In the sand we are WOT at redline for sometimes up to 10 minutes under heavy load. And the rocky areas have been violent enough to rattle apart motor mounts and tweak frame rails.
I just want to know it will hold up to the g's of being jumped and thrown around, and if it can survive excessive heat for prolonged intervals.
Sorry if I'm being overly cautious. I've never messed with turbos before and really nervous about spending the extra money on them.
The only turbo that I would suggest for him over an S366 would be a 467 with a 83mm turbine wheel. the wheels are basically the same size... and you step up to a 400 chassis from the 300 which gets you a turbine shaft thats almost twice the size of the S300....
Given his statement of how the truck will be used... the S467 would probably be the best choice.
I changed my mind about dual plennum intake, I think the intercooled holley high ram would be better than attempting a custom intake with my mediocre tig skills.
John, the S472 is the smallest BG S4xx turbo that your site shows, do you offer the S467 or will twin S472 be good enough for my power and spooling needs?
I'm also curious about wastegates and blow off valves, what would be the best size? I'll be using an electronic boost controller.
Got any pics of your truck? Is you radiator / oil cooler mounted at the rear?
a pair of 40mm gates and a 60mm BOV is more than enough for this.
I'll leave the thread up if there's anyone looking for similar.
