Boost a pump and boost.
Old Jun 26, 2015 | 06:31 AM
RBCUDA's Avatar
Default Boost a pump and boost.
Just wondering if you guys are using the pressure switch that comes with the boost a pump or something different to turn it on under boost?
Old Jun 26, 2015 | 06:59 AM
conan's Avatar
Don't waste your time with a boost a pump. Put a big enough single pump or a dual pump setup in the car and be done with it. I had a boost a pump on a single Walbro 255L and it would still loose fuel pressure. Just my $.02
Old Jun 26, 2015 | 07:14 AM
rotary1307cc's Avatar
They make a huge difference
Old Jun 26, 2015 | 09:52 AM
Forcefed86's Avatar
Can’t see why you’d need/want to use something else to control it? Boost switch works great.
Old Jun 26, 2015 | 10:18 AM
RBCUDA's Avatar
Just wasn't sure if people were using it or something else. Thanks for the info guys.
Old Jun 26, 2015 | 10:51 AM
conan's Avatar
You have had good success with a boost a pump ? I'm asking because the Kenne Bell BAP I ran was slightly better than the hot wire kit but I would still loose fuel pressure when I got up in the 5,000 + rpms. Lonnies double pumper was the first setup that held 58psi of pressure to the 6,700 rpm mark.
Old Jun 26, 2015 | 11:00 AM
Detoxx03's Avatar
I used a Kenne Belle bap successfully. Recently sold it but it supported 780rwhp just fine.
Old Jun 26, 2015 | 12:50 PM
RBCUDA's Avatar
I'm just trying to get to around 600hp. Racetronix says my pump will support around 550. was hoping with a BAP I'd be good for 600 or just over. Plus I plan on running meth.
You obviously had other issues
I can say that a friend was out of pump with twin 044s at 20lbs of boost on e85 making 1kwhp
Install booster and he now has run up to 26lbs and over 1250rwhp and not out and that was on e98
Old Jun 26, 2015 | 01:30 PM
RBCUDA's Avatar
What? I haven't tried anything yet. I'm just thinking that a BAP might get me where I want to be without going dual pumps just yet.
Old Jun 26, 2015 | 01:38 PM
Hank Peabody's Avatar
Casper voltage booster works great and goes off of TPS, only $80. It just plugs inline with the TPS plug and makes the alternator spit out 15-16v at a certain throttle position(I think it just fakes the regulator into thinking the system is low on voltage). Ive had mine for a few years and about 4k miles and it always works. Megasquirt, MSD6010 and Holley EFI don't mind or act up with the 16v.
http://www.summitracing.com/parts/cei-102130/overview/
Old Jun 26, 2015 | 01:45 PM
conan's Avatar
Interesting I guess my single walbro 255 might have been on its last leg, because I am no where near those power levels.
I think he was talking to me as to why my KB BAP wasn't working like some of the others that have had success with them.
Old Jun 26, 2015 | 05:13 PM
oscs's Avatar
Meh.. I've run my dual 044's up to 26lbs on E85 and haven't ran into fuel problems. What size feed/return was he running.
Old Jun 26, 2015 | 09:18 PM
Where is your trap to back the power? He went 165 on 1000 at 3200lbs. Never this hear on the 1250
Just because you have the boost doesnt mean you have the power or fuel consumption
An 044 is capable of 425lb/hr at 70psi, which is is where you will be even with. Low base of 43
So 850lb/hr of fuel with two.... Use even a very efficient. Bsfc of .75 for the e85 and you are at 1130 fly wheel HP max
Old Jun 26, 2015 | 09:29 PM
oscs's Avatar
Give me a few weeks to get my **** back together and I'll make it happen. I've seen plenty of cars make 1k on 044's
Old Jun 26, 2015 | 09:43 PM
Lol yes then you can
Old Jun 26, 2015 | 09:47 PM
oscs's Avatar
It's gonna be tight but it's possible. The calculations I was doing in March put it close.
Old Jun 26, 2015 | 09:54 PM
RBCUDA's Avatar
This seems to have gone another direction..
Old Jun 26, 2015 | 09:58 PM
oscs's Avatar
Welcome to LS1tech
Old Jun 27, 2015 | 12:16 PM
RBCUDA's Avatar
I've been on here for a while, just don't post that much. Hell the same thing has happened on another post I started.
