dynoed my 5.3l turbo motor N/A
I know how did you do it without the turbo! Had someone interested in the long block. Deal feel through. Put a victor jr on it with a 6ls 6012 box and a set of dyno tech headers. I was very surprised at the power it made.
With 25 degrees of timing. 514 hp@6300 and 489ftlbs @5000.
This is a stock bottom end 5.3l flat tops, with a custom grind comp cam in it. BTR platinum spring kit w / titanium retainers. Truion upgrade. EBay head studs and felpro mls head gaskets. Standard JY stuff. Just thought I'd share it with you guys. Could have played with the timing curve a little more and could've put some more fuel in it. But i was out of time. Let know what you think.
Motor is a aluminum 5.3l with flat tops. 799 heads. Block was decked and touch honed. New hastings rings. All stock lowwer end. Reused the rod and main bearings. Felpro MLS head gaskets ebay head studs. Btr platinum spring kit. With this cam.
I had a 4th Gen Fbody with a 9.2:1 LM7 equipped with 706 heads, LS1 intake, stage 2 cam and 1 3/4 long tubes made 395 to the tire through a T56 and a 10 bolt...
I would say those numbers aren't too far off...
Curious to the thought proccess on that camshaft...must've been planning a pretty small turbo.
This motor was or will go into my 5000lb mud truck. Turbo is a s475 83mm turbine 1.10t6. The cam was what the guy at comp ground up for it.
I didn't turn it any harder because it started to lay over. And I had a guy looking to buy the long block so I didn't see the point of beating it up on the dyno.
