stock bottom lq9 and t7875 results
Old 09-16-2015, 09:42 AM
transaminator99's Avatar
Default stock bottom lq9 and t7875 results
figured id share my results
99 trans am
stock t56 with pump
lq9
arp rod bolts
procomp head studs
222 224 .581 .581 114lsa cam
ls9 head gaskets
stock 317 heads w btr dual springs
btr pushrods
turbonetics 7875 turbo on on3 hotside
780rwhp 811rwtq on 20psi , also had alot of tire spin issues
Old 09-16-2015, 09:48 AM
Meth Sled's Avatar
Interested in where you found your rod bolts.. That setup should be pretty fun!
Old 09-16-2015, 09:49 AM
2000GTP's Avatar
Very nice results!
What kind of fuel system upgrades are you running?
Old 09-16-2015, 09:53 AM
i just got the rod bolts from summit , and i have 60lb seimen deka injectors , walbro 450 with a stock pump as a second pump , boost referenced fpr , evap line as return , stock lines and rails
Old 09-16-2015, 10:05 AM
DavidBoren's Avatar
Good start, sir. I think it needs more injector, personally. Probably some 80's, at least, maybe some big boy 1000cc injectors and burn some corn.
700+ has to be pushing on those 60's pretty hard. But then again, I think you need to revisit your entire fuel system and run new teflon lined -8 to new rails and -6 back for the return.
Just my opinion, take it for what it's worth. And remember, I don't know ****.
Old 09-16-2015, 10:19 AM
Forgot to mention it has an alky control methanol kit
Old 09-16-2015, 10:22 AM
Rise of the Phoenix's Avatar
Post up some pics of the setup. I too am surprised the 60lb/hr injectors got you as far as they did.
Old 09-16-2015, 10:29 AM
I'll take some this afternoon , I work for Steve Williams at efi performance , he's had several cars between 800 to 850 with 60lbers , not naysaying just talking, seems like offif you have abrfpr , pump to support it and return they'll hishold a lot
Old 09-16-2015, 10:32 AM
How was the On3 hot side? Did you do up your own cold side?
Old 09-16-2015, 10:39 AM
It's all on3 , I can't complain it's been on the car a couple years and hasn't given me any grief , there's a couple things I'dlike to do like vband the manifolds and swap some of the cold side piping cuz I don't like where it's run , but all in all its a great kit
Old 09-16-2015, 10:46 AM
IronBlocked's Avatar
Da aaaaaaaamn
Old 09-16-2015, 10:51 AM
Cool. Wasn't sure how much altering of the kit you had to do to make it fit/work. I've read mixed reviews. I'll be looking forward to seeing the pics.
Old 09-16-2015, 04:20 PM
stoverz28's Avatar
Nice numbers. What kind of rpm did it spin to? Did boost hold all the way to the top?
Old 09-16-2015, 04:59 PM
Thank you , we took it up to 6600 and it held great , maybe dropped 1psi
Quick Reply: stock bottom lq9 and t7875 results
