Truck or LS3 Manifold for (Hot side) turbo setup
Well from expirence manifolds aren't as potent for a gain when using boost. People use the Holley or fast and pick up between 10-30 hp, which yea is a gain but when you're spending 700-1000 dollars on an intake I would rather turn the boost up 1 psi and get the same result. I don't think it will matter which intake you use they'll all be near the same result but the truck one might give you a bit more torque since that's what it was designed for.
My fault I didn't catch the exhaust part makes sense now. Should be the same result though each are designed about the same I believe the only real difference would be length because the different heights of the vehicles. I would reccomend going with a set that has the most room.
