Anything to gain if I upgrade s480 & run same psi?
As title states I'm curious if I were to upgrade my s480 to some billet wheel and reduce my A/R to 1.10 will I gain hp if running same psi? Really hate to spend the money just to have it spool faster. Turbo is on a 408 stroker.
Lots to gain with the new billet wheels they have more blade length and move more air. Couple that with the t6 1.10 housings quicker spool and it will be a big change. If your not pushing your current turbo past it's limits I don't see the billet wheel spooling any faster than the cast. If you just want faster response, I'd order the 1.10 T6 and install it on what you have. Then go from there if you max out you're current compressor.
