Hey guys, help me with my fuel pressure please
https://ls1tech.com/forums/fueling-injection/179270-0psi-fuel-pressure-eeeek.html
Yeah I normally dont link threads but I need some speedier answers...
Basically, I am running a Racetronix kit w/42lb SVOs on a my TA with Stage II 6.0L heads/TR224/227/D1SC making 8lbs or so.
About 6k at WOT the fuel pressure drops to 48-50psi Suggestions please. Ad an inline pump maybe?
Thanks
Thanks
I had the Racetronix dual pump kit + SpeedInc. Fuel rails. My fuel pressure dropped just like yours. I put in a #8 teflon feed line a boost reference regulator and a #6 return line. That fixed it. I did also modify the fuel pump setup. It comes with a 5/16 T, I had a shop make a 3/8 to 1/2 Y off of the fuel pumps (since I had to put in a #8 bulkhead anyway). I don't know if that was neccessary. I wish I had taken a picture because it was a very slick setup.
Same here man.... went a little over board but hey....
Fuel System
Sumped Stock Tank
Bosch 420L/hr External pump
8-an Braided line as Feed
Stock Feed as return
Aeromotive Regulator
Na$ty Performance Billit Fuel Rails
Motron 60# Fuel Injectors
Mine's steady as a rock and i only set my FP at 56 psi.
Kyle
Fuel System
Sumped Stock Tank
Kyle
