LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   It's Turbo Time (https://ls1tech.com/forums/forced-induction/1809575-its-turbo-time.html)
Tuckin15s Nov 10, 2015 10:59 AM
It's Turbo Time
Hello all!
This is my turbo build on my 2003 ECSB s10.
Current specs on the truck
  • 2004 5.3 with a 224/224 114lsa cam 7.4 hardened pushrods dual springs ls7 lifters
  • ls6 intake
  • 706 heads with arp head bolts
  • 411 pcm
  • 4l80e with stock for the time being
  • 7.5 10 bolt with zexel torsen carrier and 4:10 (it died about 2 weeks ago)
  • charcoal interior that is MINT
  • some flashy autometer gauges lol
Plans for this winter
  • Borg Warner S475 standard cover and cast wheel (for the time being upgrading to a billet wheel next year)
  • TurboSmart race port 50mm BOV
  • TurboSmart powergate 60mm wastegate
  • All stainless steel hot side retaining full exhaust
  • 3200 stall converter and a little shift kit for the 80e
  • gm 2wd s10 offset 8.5 with 3:42s, auburn posi, 30 spline axles and a perfect launch dif cover
  • Some more gauges
  • Traction bars
[/LIST]Some Pictars
https://scontent-ord1-1.xx.fbcdn.net...94&oe=56FA0EAD
https://scontent-ord1-1.xx.fbcdn.net...d7&oe=56C0F897
https://scontent-ord1-1.xx.fbcdn.net...7b&oe=56C67BA7
https://scontent-ord1-1.xx.fbcdn.net...df&oe=56B4F6DE
https://scontent-ord1-1.xx.fbcdn.net...b1&oe=56F1F0DC
https://scontent-ord1-1.xx.fbcdn.net...69&oe=56B3920F
https://scontent-ord1-1.xx.fbcdn.net...56&oe=56C800E9
https://scontent-ord1-1.xx.fbcdn.net...24&oe=56B6D9C4
A pic of the swap before the turbo build
Whats going on now
https://scontent-ord1-1.xx.fbcdn.net...6b&oe=56C01B48
https://scontent-ord1-1.xx.fbcdn.net...2d&oe=56C790BE
https://scontent-ord1-1.xx.fbcdn.net...bf&oe=56F32661
https://scontent-ord1-1.xx.fbcdn.net...e8&oe=56BE6DCB
Just a little size comparison
Thanks for looking.
Tuckin15s Nov 10, 2015 11:02 AM
6 Attachment(s)
Nothing huge tonight for progress but a little interior work.
So know one makes a 3 gauge pillar pod for the 2003 s10 interior being the headliner and a and b pillars are different than the 98-02 trucks. So I cut up a glowshift 98-02 3 gauge pillar pod and starting cutting it up to mold it into the factory 2003 a pillar.
Attachment 643370
Attachment 643371
Attachment 643372
Attachment 643373
Attachment 643374
Attachment 643375
Some more hotside parts arrived tonight as well hoping to get the turbo sitting on the manifold this weekend.
Thanks for looking!
- - - - - - - - - -auto merged double post- - - - - - - - - -
Silky pajama bottoms :fuckyeah:
SenorThumpy Nov 10, 2015 01:00 PM
i love seeing dimes on here. in for progress. Keep it up man!
rpturbo Nov 10, 2015 05:46 PM
I really like what your doing, and plan to do almost the same thing here soon. Can you post up what parts your using for your header, and who you got them from? I guess your using truck accessories? I have Corvette.
Do you know what your truck runs N/A? I have almost the same setup, except with a 60E currently and LS6 intake. On crappy tires 2.0 60', mine ran the best of a 13.10. Curious what your fuel plans are?
Tuckin15s Nov 28, 2015 09:33 AM
Some progress on this thing
https://cimg8.ibsrv.net/gimg/ls1tech...cfa3cfe517.jpg
https://cimg0.ibsrv.net/gimg/ls1tech...ff2820b68e.jpg
Intercooler mounts gonna be perfect, this intercooler is some stage 2 intercoooler out of a subaru.
https://cimg2.ibsrv.net/gimg/ls1tech...a72d73e2d0.jpg
https://cimg7.ibsrv.net/gimg/ls1tech...15a6be838b.jpg
https://cimg2.ibsrv.net/gimg/ls1tech...29a5d30420.jpg
Mock up air filter, its a little tight haha
https://cimg5.ibsrv.net/gimg/ls1tech...a3b55b0b01.jpg
tacked up and the turbo sitting on the manifold fits so perfect.
https://cimg3.ibsrv.net/gimg/ls1tech...c625ef22f7.jpg
hood clearance
https://cimg6.ibsrv.net/gimg/ls1tech...b1f3925942.jpg
Could I get a mod to move this to the forced induction section please.
brandon6.0 Nov 28, 2015 10:50 AM
Nice build. Do u think downpipe is gonna be tight out the back? Or are u gonna do a fender exit?
gtfoxy Nov 28, 2015 11:05 AM
1 Attachment(s)
Yeah that filter is being criished a bit. On my Blazer I put a 90* elbo off my turbo so the MAF & air filter were down behind the headlight.
Hard to see in this pic, but you get the idea.
Tuckin15s Nov 28, 2015 01:36 PM
it will be a little tight but doable. I will be doing a 4" down pipe with a cut out then step it down to a 3" after the cutout ran into my already existing exhaust.
brandon6.0 Nov 28, 2015 08:37 PM
ok cool. I have a 97 rcsb s10 laying around. the original 2.2 took a dump so It might be a pretty good contender for a new project!! may try a junkyard sloppy mechanic build on it.
prostreet1967 Nov 28, 2015 09:19 PM
5 Attachment(s)
[QUOTE=Tuckin15s;19034180]Nothing huge tonight for progress but a little interior work.
[IMG]http://i1382.photobucket.com/albums/ah262/Ross
Patrickmartin/20151109_181823_zps9qodlqif.jpg[/IMG]
Attachment 642135
Attachment 642136
Attachment 642137
Attachment 642138
Attachment 642139
Thanks for looking!
Nice build
prostreet1967 Nov 28, 2015 09:21 PM
Where u get kit for log? I've been looking for one
Tuckin15s Nov 28, 2015 10:05 PM
Yeah man there you go. Too bad the 97s are the worst to wire up haha.
Prostreet I pieced the kit together I order the flange off of ebay from modern automotive performance and the other metal from ace race parts on line the log is schedule 10 stainless 2" the 90s are long radius schedule 10 1.5".
Tuckin15s Nov 30, 2015 06:35 AM
This is the 2003 only pillar pod finished up.
https://cimg7.ibsrv.net/gimg/ls1tech...f9afe52d49.jpg
https://cimg8.ibsrv.net/gimg/ls1tech...e50bb9f34a.jpg
https://cimg9.ibsrv.net/gimg/ls1tech...9ec459aedf.jpg
Waiting on the rest of my metal from ace race parts for the hot side. Then I will get assembling the cold sided then pull the motor to change the oil pan and drill and tap for the oil drain back.
Tuckin15s Dec 7, 2015 01:42 PM
Updates
https://cimg4.ibsrv.net/gimg/ls1tech...8cfe18195e.jpg
Top innercooler mount
https://cimg6.ibsrv.net/gimg/ls1tech...7a80da46bb.jpg
https://cimg8.ibsrv.net/gimg/ls1tech...39bf830159.jpg
https://cimg9.ibsrv.net/gimg/ls1tech...cdd9b0f2db.jpg
https://cimg0.ibsrv.net/gimg/ls1tech...2947523c94.jpg
D-WAKE Mar 8, 2016 04:32 PM
Nice build! Got pictures of the driver side manifold?
Tuckin15s Mar 10, 2016 11:37 AM
Check this thread out its the most up to date. I don't update this one at all
http://www.s10racer.com/site/index.php?topic=10048.0
© 2026 MH Sub I, LLC dba Internet Brands
