Any whipple 2.9 swaps? https://cimg2.ibsrv.net/gimg/ls1tech...ae04cd777c.jpg Has anyone used any of the various swap brackets with a whipple 2.9? Looking to put one in my ls swapped g body Like this? https://cimg3.ibsrv.net/gimg/ls1tech...dc2a2409de.jpg https://cimg4.ibsrv.net/gimg/ls1tech...c789fd53cc.jpg Or this? |
You don't see many of them because it's impossible to fit the thing under the cowl and hood, plus I'm pretty sure it's a pain in the ass fabricating everything in order to make it work. |
The 2.9 should fit . If not there is always a 2in cowl hood . Main hurdle with my set up is moving the alt over to clear the throttle body and bypass valve |
Originally Posted by jimmyg
(Post 19038767)
Originally Posted by supermaro
(Post 19038938)
Do you know if you'll be running 5th gen Camaro offset or vette offset? I would suggest 5th gen. The tensioner design is much better. Also if you're looking for 5th gen accessories I have a spare set(alt, damper, ps, water pump and brackets). Running the 2.9 whipple on my TBSS and love it. |
(Post 19038938)
Do you know if you'll be running 5th gen Camaro offset or vette offset? I would suggest 5th gen. The tensioner design is much better. Also if you're looking for 5th gen accessories I have a spare set(alt, damper, ps, water pump and brackets). Running the 2.9 whipple on my TBSS and love it. https://cimg1.ibsrv.net/gimg/ls1tech...5d38c548d2.jpg My set up now. Going with low mount pass side ac and maybe one of the brackets I posted . That's the plan anyway |
https://cimg0.ibsrv.net/gimg/ls1tech...f6ecf63c1c.jpg I'm thinking this would work Uses truck offset |
(Post 19039033)
https://cimg0.ibsrv.net/gimg/ls1tech...a5a40dae8e.jpg Keeping dbw I'm going to try to mount compresser low on pass side either truck or sanden Like this |
(Post 19039093)
What car is this in? Spacing? |
(Post 19039271)
Holley bracket? |
Anyone else running this? Curious to know how they compare to the ZR1 SC swaps. |
Not sure if anyone said this before but Whipple does not make a 2.9 on the 4th gen Camaro belt line. The first pictures you posted looked like they were on the 4th gen line. So you are either stuck with the 5th gen/truck or Corvette belt line. |
Its a giant pain in the ass...lol We have a 3.4 whipple on a c5z Made an intercooled lower manifold...easier to place the blower where it fits vs changing the accessories A 6 inch cowl barely clears the case as well If i was starting over from square 1 i would have put turbos on it https://cimg8.ibsrv.net/gimg/ls1tech...13add194de.jpg https://cimg2.ibsrv.net/gimg/ls1tech...b12a01130a.jpg |
Originally Posted by 70 Bug Mid Engine
(Post 19069716)
Originally Posted by mkvamso
(Post 19069864)
Put a 2.9L Whipple on my brothers 08 z06 with head and cam. 660rwhp @ 6psi, 730rwhp @ 8psi. Stock Short |
© 2024 MH Sub I, LLC dba Internet Brands
