How much power will a turbonetics t76 support?
Old 11-19-2015, 09:07 PM
SSLogan's Avatar
Default How much power will a turbonetics t76 support?
Hello, i have a 2000 Camaro SS with a single turbonetics ball bearing t76 with a .96 ar. I am fairly new to the turbo world, and was wanting some input. Right now it is on a bone stock ls1. I have a 5.3 that I'm building up with 3.905" forged Pistons in the 9.0-9.5:1 range, a tick stage 2 turbo cam, head studs, good head gaskets,and probably some ls6 heads. I would like to get 600+ rwhp on 93 octane, and was wondering if this turbo would support my goals. Any info would be appreciated. Thanks, Logan.
Old 11-19-2015, 09:45 PM
Honeycutt's Avatar
Yes, if 600whp is your goal I'd say so. If it's a 65mm turbine T76, then it'll start choking around 650-700.
Old 11-22-2015, 02:04 AM
Johnv's Avatar
I have a T76 on a 347cu making 775rwhp, but I do have a 1.32 ar exh housing.
600rwhp won't be a problem
Old 11-22-2015, 08:13 AM
twinturbogbody's Avatar
It was a while ago but I had a single SuperT76 turbonetics with a .96 housing on a V6 buick that made at 29lbs of boost made 689rwhp very fun turbo but will definitely give you what you want
Old 11-24-2015, 09:50 PM
FourG63 97GST's Avatar
that's cake, I broke 600s with a PT67
Quick Reply: How much power will a turbonetics t76 support?
