Pushing water out radiator under boost help
#81
#85
I think he means to watch the gauge, while you're beating on it.
Good idea with a light.
#86
Unfortunately not auto. It will make a few pounds revving it but that's about it. It will make about 10# on the 2 step though. Ill see if I can secure the gauge and make a pull with the go pro on it. May be difficult but i'm up to a challenge.
#88
Ill see what I can do. After I replaced the coolant cap the spray went away under the hood. I also noticed when I did the pressure check I forgot to put a clamp on the stem vent so im sure some spray was coming from that too.
#94
I am not sure if it has been mentioned but what is your AFR for these pulls? Also, check your injectors to see if they have developed the black goo of E85 death. When my injectors went black I blew out the driver's side HG because it was lean but you would never know it looking at the plugs or otherwise.
#95
#98
