Pushing water out radiator under boost help Heres the rough setup: 99 Camaro M6 370" ironblock forged internals Texas Speed PRC 260cc LS3 aftermarket casting heads Ls9 gaskets and heads were torqued to around 90ft # I believe (dont remember exactly but I know its more than ARP called for) F1A on about 21# boost car makes 941/866 on a dynojet Heres what happened: took the car out last night street racing. Made probably 7-8 2-4 gear pulls dang near back to back. After a few pulls i started to smell coolant. Didn't think much of it until we pulled off the side of the highway when done and looked like the car was pushing water. I still have a tiny overflow Probably a hair bigger than a coke can (I know I need a bigger one) and it was complety full and running out and also looked like coolant was pushing out around the cap as you could see it running down the radiator and also spray ing the engine bad and bottom of the hood. Even the back bumper had coolant spray all over it. I know I kinda had the same problem with the car even with the stock motor and D1 on it but I never ran it as hard as I did last night so I never saw it this bad. Think its a combination of the small overflow tank and maybe a old/bad radiator cap or are the heads lifting? Car ran completely fine and never got hot ect. |
I'd say heads lifting. Do you have head bolts or studs? |
If it didn't overheat and there are no leaks, you more than likely lifted a head an over pressurised the system. I'd pull the heads and take a look. |
(Post 19064260)
yep, lifted a head or split a cylinder wall would be my guess. You could try changing the cap & backing off the fluid level in the res, but I would pressure test the coolant system & do a leak down. |
(Post 19064261)
Originally Posted by gtfoxy
(Post 19064270)
If it didnt broke, I'd do a set of better studs, more clamping force and a new gasket will go a long way assuming the decks are good to go |
The heads are brand new with maybe 300 miles on them. It has aarp head studs in it now. |
Detonation could lift a 22bolt head |
Originally Posted by rotary1307cc
(Post 19064304)
Originally Posted by speedfreak2685
(Post 19064285)
Going to pressure test it later. Highly doubt it went as far as slitting a cylinder wall lol. Is it blowing any water vapor out the exhaust? Have you checked the plugs to see if any look like they are burning coolant? |
(Post 19064314)
If it's not misfiring it more than likely isn't a cylinder wall. I've just had it happen to me & it did the same thing, but would misfire. Fouled the plug like crazy as soon as you put a load on it. Is it blowing any water vapor out the exhaust? Have you checked the plugs to see if any look like they are burning coolant? |
A dyno is completely different than a long real world pull |
(Post 19064320)
2 Attachment(s) Here is a pic of one of the plugs. Same plug, just one with flash and one without. i dont know much about reading plugs. I did a pull dang near right before I shut the car off last night as well fwiw. Attachment 641674 Attachment 641675 |
(Post 19064310)
It had no detonation when tuning it but i wasn't logging last night when running so no way to say what was going on last night. Wouldn't think it would have been any different though. |
Originally Posted by caMnaro
(Post 19064351)
How cold was it out were you were racing? Depending on the temperature the intercooler may have gotten heat soaked with so many back to back pulls. Once the IATs went up it could have detonated and lifted the heads. Do you have a meth system on the car? |
Looks hot to me with signs of det on the porcelin to me. How timing? |
(Post 19064416)
© 2024 MH Sub I, LLC dba Internet Brands
