Huron speed v2 kit, swaybar fitment Just got my car back but alas my strano front sway bar won't fit. Does anyone have other aftermarket options for a front sway bar that fits with the v2 kit from huron that keeps your ac? |
not sure about after market but i believe it was designed to fit around a stock SS or WS6 sway bar, which i believe was bigger then the standard z28 and trans am. might want to look into finding one of those. |
Kits not made to fit around sway bar, stock or aftermarket, i have strano suspension set up on mine with ac turbo kit also, i had to make custom brackets that dropped my sway bar about 6in to get it to work. |
Originally Posted by ToxicWS6
(Post 19137446)
Kits not made to fit around sway bar, stock or aftermarket, i have strano suspension set up on mine with ac turbo kit also, i had to make custom brackets that dropped my sway bar about 6in to get it to work. Thank you for the suggestion, I am looking to see if there were any other aftermarket installs that are close to stock or SS in shape that worked for others, like UMI's 35mm for example. |
(Post 19137446)
7 Attachment(s) Here are some photos showing the V2 AC Hotside mocked up around a factory sway bar. Any changes in bend locations or much larger diameter in an aftermarket bar over the factory may not clear, however it was built around fitting the factory :cool: Attachment 637574 Attachment 637575 Attachment 637576 Attachment 637577 Attachment 637578 Attachment 637579 Attachment 637580 |
ToxicWS6 I know this old thread but by chance do you have pics of brackets? |
© 2024 MH Sub I, LLC dba Internet Brands
