1986 Ford LTD/L92/BW S-480/Holley EFI Street Car
Old 09-07-2017, 09:52 AM
  #141
Bad Apache's Avatar
Great improvement! Knocking on that 9 second pass. Chassis worked great on that run as well.
Old 01-05-2018, 09:26 AM
  #142
408GT's Avatar
Last season with the car I learned a lot and had a good time with it. With the help of 3 Window on here I was able to get my tune a lot better than it was and get my boost controller working really well. Unfortunately on the last pass of the season I hurt it. On the release of the t-brake it spun and I peddled it once to regain traction. It hooked and went a 6.5 @ 115 w/ a max boost of around 17 iirc. I got the motor out this week and found #5 rod just barely bent (I was on pump gas no meth). I bought a set of rods and pistons from Steve Morris and will be dropping it off at the machine shop today. The new pistons will drop my c/r from 10:7 to 9:1 respectively. I'm hopping to turn up the S-480 now with the decrease in compression to get the turbo in its more efficient zone. I'm going to go over the car while it's down and try to pull some more weight out and clean things up a bit.
Old 01-05-2018, 09:19 PM
  #143
Bad Apache's Avatar
That sucks. At least it was the last pass of the season. Thanks for updating the thread. Steve weighed his LX recently. I believe it's 3050 w/o driver currently. He still hasn't done the manual window conversion. He weighed the pieces and it was a very small difference. Good luck on the diet!
Old 01-08-2018, 07:42 AM
  #144
408GT's Avatar
I've been SBE all this time and it's done well so I won't complain. I think it will be good to get some compression out and have some good components in the bottom end.
From what I've read it didn't look like there'd be much of a weight difference from manual to power windows (on the Mustangs anyway). I'd like to get down to that weight, but I don't want it to feel like a tin can.
I built another one of these cars a few months ago. It's a white 85 LTD just like this one, but I used an LS-1 and a 4L60 on the stock computer. It's been a good DD so far. I even drove it down to Daytona for the Turkey rod run and got 21.8 mpg.
Old 01-08-2018, 12:09 PM
  #145
Bad Apache's Avatar
Awesome DD! Steve's isn't a tin can by any stretch. Just has a sbf and T5, and lots of small weight removal. I would rather build more HP than strip a driver down too much. Takes all the fun out of driving it quickly. Look forward to your results next season.
Old 01-08-2018, 01:20 PM
  #146
408GT's Avatar
I'm sure all of the turbo stuff and 4L80 is where my weight is over his. Hopefully with the built bottom end I'll just be able to turn up the power to make up for the weight.
The 85 is a nice DD, I'm sure it'll end up with a turbo before too long haha.
Old 01-08-2018, 04:45 PM
  #147
7 Second Club
ls3fox's Avatar
how much timing were you running? and how do you have the boost controller setup
Old 01-08-2018, 04:50 PM
  #148
408GT's Avatar
I'd have to go back and look at my timing table to be sure, but I think I was around 14* @ 18 psi (pump gas) then running a flex fuel sensor to add more timing based on E content.
I'm using a single 3-port solenoid using boost vs time.
Old 05-17-2018, 10:52 AM
  #149
408GT's Avatar
Finally got the car back together and running again. I switched to a dual fuel setup w/ two separate fuel systems so I don't have to worry about finding E since our local station quit carrying it. Here's a quick video:
Old 05-17-2018, 11:54 AM
  #150
Bad Apache's Avatar
Bout time!
Old 05-17-2018, 12:44 PM
  #151
408GT's Avatar
Originally Posted by Bad Apache
Bout time!
I know right? Now that I finally got it going there's rain in the forecast for the next 15 days! ugh
Old 05-17-2018, 05:05 PM
  #152
Bad Apache's Avatar
Been raining here since Sunday. I feel your pain. Can't even drive it to tune a little.
Old 05-30-2018, 01:46 PM
  #153
408GT's Avatar
Still raining here, so haven't been able to drive it. Here's a walk-around video:
Old 05-30-2018, 09:33 PM
  #154
Bad Apache's Avatar
Quit sending that stuff up here. Racetrack has only been open like 3 days this year.
Old 06-14-2018, 08:08 AM
  #155
408GT's Avatar
I drove the car 1 hr out to the track last Friday night and was able to get 3 passes on the car. First pass I was having to start over with my boost controller and just trying to get some data, so I just populated the table w/ 20% DC to see what it would make. The car left good and made a good clean pass of 9.8 @ 136 w/ a 1.4x 60'. It made about 3psi on the brake and ramped straight to 14 psi in 1.5 sec and leveled off at 9psi. The second pass I doubled the DC and it made 18 psi, but it left so hard that I hit a safety cut right out of the hole. The last pass I fixed the safety cut issue and turned it up a little more, but it spun out of the hole and I had to peddle it once. The car ended up weighing 3455 w/ me (170).
Old 06-14-2018, 08:13 AM
  #156
Forcefed86's Avatar
136 at that weight and boost is great! So what did it trap the last pass turned up?
Old 06-14-2018, 08:41 AM
  #157
408GT's Avatar
Here's a video of the first pass.
Force it went 147 mph on the last two passes. I'm thinking about going from the 3:27 to a 3:55. What do you think about that?
Old 06-14-2018, 09:32 AM
  #158
Forcefed86's Avatar
Sounds like you still have a little room to turn it up... but at that weight, I think the mechanical advantage will help the 60’-330’ for sure. If you’re combo is setup to take advantage of more RPM and can plant the tires... it should be faster all around. If your top end isn’t setup to take advantage of the RPM, the lower gear might keep you in your power band happy place. With an OD trans, might look into even more gear. I’d shoot for 7kish thru the traps in the ¼.
Old 06-14-2018, 10:01 AM
  #159
408GT's Avatar
Great, thank you for the info. The cam is one that JFR did for it @ .575/.596 221/230 on a 114, but we degree'd it on a 109.5 CL. A little more seat time and dialing it in and I hope to go low 9's.
Old 06-14-2018, 04:01 PM
  #160
Bad Apache's Avatar
Coming right along. Glad you got it back out again and made it home to boot.
Quick Reply: 1986 Ford LTD/L92/BW S-480/Holley EFI Street Car
