Picked up a pair of the new “Typhoon” 72/68 Turbonetics clones.
http://www.ebay.com/itm/231916193339...xe=exe,ext=ext
Available in a T4 or T3 housing. I went with the cheaper .84 T3. They shot down my $225 offer and took my $230 offer. So $460 shipped for the pair.
The boxes they came had “HX-40” stamped on them. The “.84 T3” housing looks to be a 16-18cm Holset exh. housing with a 4” v-band discharge. More like a 1.21-1.37 AR if you use the popular CM to AR conversion charts.
Double checked the wheels and the advertised dimensions appear to be correct.
Compressor Housing:
4" Inlet Diameter
2.5" Outlet Diameter
Compressor Wheel
.70 A/R
IND 72.35 MM
EXD: 102.86MM
0.84 A/R T3 4" V-band discharge
Turbine Wheel
IND 79.00MM
EXD 68.40MM
Looks like they also have an updated comp wheel design with extended tips. Machining of the comp housing left some cast flashing that looks like it could take flight at any moment. I’ll file those down down before I run it. Aside from that it looks like a nice piece…kinda like most china turbos these days. Time will tell. Hope I can spool the bastards with a JY LS!
Compressor Housing:
4" Inlet Diameter
Compressor Wheel
.70 A/R
IND 72.35 MM
EXD: 102.86MM
Turbine Wheel
IND 79.00MM
EXD 68.40MM
Also noteworthy is the T3 housing. Weird design. Almost looks like a surge housing on the exhaust side. Not sure what the idea behind that design is. But it is going to make packaging a PITA. Think I’ll neck it down to 3” as quick as possible. What’s annoying is it looks like the t4 housings are actually smaller and have 3” vband outlets that would have been much easier to work with. For the extra $40 I should have just gone that route.
