Stock 5.3, Valve float at 4800RPM???
Old 05-13-2016, 06:20 AM
LS_Turbo_Nova's Avatar
Default Stock 5.3, Valve float at 4800RPM???
I have a 100% stock 2002 5.3 with unknown mileage that I put in my car with my turbo kit while I finish building my other engine.
Im running 10psi, the car launches and feels good until 4800rpm, its like its bouncing off a rev limiter. Same exact RPM every time. My rev limiter is set at 6000 and plug gap is .026, so those 2 things are ruled out.
Can the stock springs be causing valve float at that low of a RPM? Im not sure what else would cause it to act this way.
Im just looking for real world examples. Thanks in advance
Old 05-13-2016, 07:09 AM
93Z2871805's Avatar
It is possible that boost pressure is holding open the valves. Considering that the mileage is unknown, you could be running 200k mile OEM springs, I would personally just swap to a decent set of springs and see if you get more rpm out of it. Considering that stock LS1 springs had something like 75 lbs closed at the seat when they were new, I would think it's very possible to float worn springs under 10 psi of boost at lower rpm. Are you actually getting into boost when you hit the throttle? Have you done a compression or a leakdown test?
Old 05-13-2016, 07:18 AM
69-chvl's Avatar
Could very well be springs, but could also be spark blow-out. Anything more than .022 for me and the dam thing breaks-up like a rev limiter is engaged.
I'd tighten-up the plugs first. But, I'd throw some springs in there anyway for safety. A new set of LS6 springs could be had for like 60.00 and are drop-in.
Yes I can build 8 psi on the footbrake at 3500 rpm and it goes to 10psi as soon as I take off. But then it stays steady at 4800rpm and 10psi.
Old 05-13-2016, 07:22 AM
I'm gonna install ls6 springs tonight. Its just weird I never heard of valve float that low of a RPM.
Old 05-13-2016, 07:29 AM
69-chvl's Avatar
I would agree with you. That's why I'd tighten up the plugs first. Actually, replace them while you're at it as they could be partially fouled now.
Old 05-13-2016, 07:32 AM
Last week they were stock plugs with .050 gap......
3 days ago I installed BR7's at .026 gap and it made no difference.
So these plugs have about 2 miles on them
Old 05-13-2016, 07:37 AM
69-chvl's Avatar
What efi system are you running? Go a little tighter on the plugs and report back.
Old 05-13-2016, 07:40 AM
No EFI, blow through with MSD6010. And before anyone makes carbureted comments, I've been blowthrough for 4 years, this problem just appeared with this engine.
Old 05-13-2016, 09:38 AM
Restricted User
JoeNova's Avatar
With the miles these can handle, its not surprising to find one with 250k+ miles that still runs good. At that point, its not surprising that the valve springs have softened and need replaced.
Which coils are you running? Heat-sink coils have a very strong spark even at larger plug gaps.
Old 05-13-2016, 09:49 AM
Non-heat sink coils. Same ones I ran on my 150k mile LQ4 that took 15psi with stock everything and revved to 6000rpm without a hiccup.
Hopefully new springs and tighter plug gap fix this. Its just weird it is exactly like a rev limiter. It wont go above 4800.
Old 05-13-2016, 10:00 AM
lurker1978's Avatar
Will it rev past 4800 with no load on the motor?
Old 05-13-2016, 10:12 AM
I'll try that tonight before swapping springs.
Old 05-13-2016, 11:22 AM
roastin240's Avatar
You could open the wastegate wide open (0psi effectively) and see if it revs past 4800 rpm. Boost contributes to holding the valves open, so turn boost off and try it
Old 05-13-2016, 08:32 PM
Just a quick update. Reving in park or neutral went up past 5000rpm no problem. I disconnected the turbo cold side and drove it and the "valve float" was now happening around 3800-4000rpm. I went home, installed ls6 springs amd left my plug gap alone. Took it out and was issue free. Trned boost up to 15psi and still issue free.
Old 05-14-2016, 07:29 AM
69-chvl's Avatar
Awesome...now get it to the track and let us know what she did
Old 05-16-2016, 10:21 AM
roastin240's Avatar
Sweet, good news man!
Old 05-16-2016, 10:35 AM
Well last year I had a setup similar to yours.....LQ4 with LS6 cam/S475/ TH350/ 3.55 gears and I went 10.52@130 on 8 PSI.
Honestly this setup with the stock cam feels like it will destroy my old setup. I will be sure to post the results when I get to the track.
Old 05-16-2016, 01:26 PM
69-chvl's Avatar
That's excellent mph for only 8psi! ****, I dont think you can even damage a motor no matter what with 8psi!
I did run ~130mph on like 10.5psi though. Just doesn't seem to do any better with anymore psi so I need to find the bottleneck if there is one.
Old 05-16-2016, 01:48 PM
Unfortunately I did. The engine ran fine for 2 years with a gt45 and stock cam at 15psi. I put the s475 on and installed the ls6 cam. When I installed the cam, the bearings looked horrible but everyone said run them......well, first time out it spun the cam bearings, that metal went everywhere, wiped out 3 mains and 4 rod bearings. All that happened in my 1 and only pass with that setup. So yea, my 130mph pass was with all those engine issues too. I had to have my turbo cleaned and inspected with only 4 miles on it because so much metal was sent through everything. I should've known better to not run those cam bearing....but live and learn.
Quick Reply: Stock 5.3, Valve float at 4800RPM???
