Need troubleshooting Help! Turbo Fairmont wont make power
Finally got my Fairmont ready to tune and on the dyno we cant figure out why it wont make power. My tuner says there is some kind of restriction but i cant think of any. He also says the VE table is acting backwards. Once it hits like 3500 rpms it bogs down with tons of fuel. We unhooked the charge pipe and we still cant make power on even an NA tune. Its like its itting a wall. Im just going to post a video so you guys can see what its doing. Please help i need boost!
NA Tune
NA Tune
Here are some more details. We took the air filter off and had the same problem still. I was thinking about relocating the grounds because i have them all in one spot behind the intake. Also i am considering that it might be a timing issue, like the cam is off a tooth since i built the motor. I am kind of at a loss. but ever since ive had it running when it is floored it goes ultra rich and bogs down. It should be leaning out if im not mistaken. The o2 sensors are turned off in the tune, and there is no rev limiter
Hard to say without more details. I'd check the mechanical side of it first. Then you'd know it was most likely a tune/ecu issue at least.
Do a compression test and see what the motor is spitting out. If you missed a tooth it will be very obvious. Healthy 5.3 with mild cam usually spit out 150-190.
Also may try putting a peak/hold cheapie tire gauge on the hotside. See if you have any big restrictions pre turbo. (collapsed flex section or something). Have to setup it up with some coils in it pre gauge/sensor like so...
Yes it is a stock ecu. I did some things today and the car seems to be running better. At least from revving it in place. I cant move it because my other car is blocking it. I pulled the intake off and found a vacuum hose not hooked up behind the intake. Not the big one but a little port underneath the big vacuum port. I also relocated the grounds, and moved my wiring harness above the intake because i had a lot of it ran underneath the intake. Not sure yet if any of this really made a difference but the car seemed way healthier.
Did a compression test on my motor and im getting around 210 psi across all cylinders. Does this mean my timing is good? The car is still bogging down when driving it under load. Starting to think it is my pcm or maybe injectors.
If your O2 is off, what makes you think it's rich? Smell fuel? Plug readings?
Cylinders not firing will smell rich, but an O2 will read lean.
Are your plugs and wires in good shape? Gapped correctly? Coils have a good ground and appropriate gauge + and - wire? Dwell settings good? All connections/splices completely solid?
Really hard to give feedback with so little info to work with...
You don't have a huge cam on stock springs... do you?
A complete rundown on your build would be very helpful. Otherwise we're shooting in the dark.
All the best
All the best
What should i gap the plugs to?
Well we worked on it all day and still didn't find the problem. We changed intakes and found the fuel pump check valve was not working. We attempted to swap injectors but the gto one's were too short. We put a couple different tune files in and fixed a fuel trim issue. The problem still existed. I am going to pull the turbo off just as a last resort and see if there is some kind of restriction. Also change the fuel pump.
Yes, they are. We loaded a 2nd pcm with a 2 bar os, and imported factory f body file and massaged settings for the 2bar map in SD and 60b Injectors. Removed intake elbow and it still went pig rich upon mediun accel. We are testing a few things on it this week.
