Notices
Huron speed twin turbo c5 z06 build, pics heavy!
Old 07-24-2016, 01:05 PM
Default Huron speed twin turbo c5 z06 build, pics heavy!
Car is a 2003 corvette c5 z06. Bone stock, m6. this will be a review of the kit as parts come in and get installed. I will post stock times and pics as the build get started. I am located in sw Virginia, and the track I run at mostly is in eastern tn at Bristol thunder valley.
Attached Thumbnails Huron speed twin turbo c5 z06 build, pics heavy!-image.jpeg
mcmuscle3 is offline
Old 07-24-2016, 01:11 PM
drag radials 275s
On drag radials, 88degrees outside<br/>Stock run
Decking board works nice to help lift the back to disperse the weight on the aluminum.
Off with the hood
Bye bye radiator
Soak bolts in pb blast to try to prevent breaking a bolt in the head. It worked for me!
Old
Going with Ngk br7ef
Old 07-24-2016, 04:29 PM
Christmas in July!!
Ah, new go fast parts!!
Clean welds grinded down from Huron for smooth air flow
Top quality work right there
Notice the thick flanges to support the weight of the manifold and turbo. Good quality
Nice think Inlet tube
Everything was shipped in heavy plastic and foam padding. Great shipping and packaging Huron!!
Vband and t bolt clamps
Intercooler shroud, nice thick aluminum
Misc parts
Old 07-24-2016, 04:30 PM
Jon hooked me up with the the full exhaust ac retaining kit. Everything received has had superb quality and his customer services is like no other.
Old 07-24-2016, 04:31 PM
SSZ
Love the car. Looking forward to more of the build. Doing any upgrades to the transmission?
SSZ is offline
Old 07-24-2016, 04:35 PM
SSZ
Wow! Just noticed the pics of your new parts after I posted. That kit looks sweet!
SSZ is offline
Old 07-24-2016, 04:37 PM
Hello power plant x2
Ac CONPONENTS drop shipped for Huron speed
Twin billet 6262s, beautiful !!
Difference between the new and old dryer
New one in, easy to get to with battery removed
Ac line
Slips on with one hand, just needs clamped. Since this is a sponsored kit and the first one, mine is not clamped, Jon does plan to revise this so don't let this concern anyone not able to get their hands on a ac Hose clamper.
Wg!!!
Test fitting v bands and wg
Test fitting manifold while waiting on, c6 oil pan and motor mounts
New plugs, gapped to 28
Old 07-24-2016, 11:58 PM
MYSTIC-1SC's Avatar
Nice build! Jon and Casey at Huron Speed are awesome guys to deal with.
MYSTIC-1SC is offline
Old 07-25-2016, 01:24 AM
im liking this build
runsfromdacops is offline
Old 07-25-2016, 04:42 AM
Heavy H.P.'s Avatar
In for the subs. Nice build you got there. Looks real good. Can't wait to see what she does.
Heavy H.P. is offline
Old 07-25-2016, 07:16 AM
Engine will remain SBE for now, also will stay stock heads and cam. Clutch is stock, tranny and diff are stock but it does have a Hoosier dte brace.
This is a complete baseline test for a stock car. I'm sure my clutch will slip, and I'm sure I will break things, but I'm testing it with this kit and will upgrade accordingly.
Old 07-25-2016, 11:56 AM
The Scammer Hammer
dr_whigham's Avatar
I'm happy for you, but aggravated as hell also, lol. I begged and PLEADED with them to make a C5 kit. By the time it's ready I've moved on to a C6Z...
Kit looks AWESOME I must say!! Hats off to Jon and crew for bringing it to fruition! Looks gorgeous!
dr_whigham is offline
Old 07-25-2016, 12:53 PM
Rise of the Phoenix's Avatar
Looks like a high quality kit. Nice looking C5 too.
Rise of the Phoenix is offline
Old 07-25-2016, 05:33 PM
Thanks, planning on busting a few hellcats, coyotes, and other non Gm products with this beast lol
Old 07-28-2016, 01:11 PM
New mounter mounts and pedestals
Old vs new
Lift the engine 2 -3" and you can pull the mounts right out. 13mm bolt and 18mm if I remember right
Old vs new
I zip tied the old heat wrap back on the new ones.
Clearance is close Clarence. Something has to change
Heat wrap and heat blanket to help protect the wires that's close
Better view
Divers side
Notice the heat wrap on the clutch metal braded hose.
More on the driver side
Heat shield from auto parts store
Huron supplied nice heat shield wrap for wires/hose. <br/>Not sure where they are suppose to go but I used some here. I will buy more if it needed else where. <br/>Losen the wires and just play around with them. This gave me plenty of room.
Old 07-28-2016, 02:38 PM
kit looking great, love this build
finewayne is offline
Old 07-28-2016, 06:43 PM
KyleLanter's Avatar
Everything Looks fantastic. Jon and Casey are great helped me out with my kit. Cant wait to see this together!
KyleLanter is offline
Old 07-28-2016, 10:06 PM
LilJayV10's Avatar
high temp heat sleeving/wrap, plastic zip ties....just something to think about
I'll be watching this closely. can't wait to see your results and how well the kit is designed.
LilJayV10 is offline
Old 07-29-2016, 08:31 AM
Yeah, you are right, but that motor mount doesn't see that much. It's on the cold side of the turbo, but not close enough to melt thanks for the point out though!
Old 08-11-2016, 07:03 PM
Old vs new ac comp bracket
Drilled and tapped
Oil feed for turbos
Remove upper control arms , lower shock bolts, and 10mm brake line bolt along with steering arm bolt to lower the front cradle. Easy job
Steering arm
New pan in
Quick Reply: Huron speed twin turbo c5 z06 build, pics heavy!
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
