LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   what ignition system mod's for very high hp? (https://ls1tech.com/forums/forced-induction/184149-what-ignition-system-mods-very-high-hp.html)
parish8 Jun 19, 2004 06:03 PM
what changes to the ignition sytems are the 800+hp guys doing. other than using the proper spark plug?
i am headed for a t88/408/nitrous combo eventualy. I am having ignition problems right now and was thinking about upgrading any parts now that will be needed at the higher level.
smokinHawk Jun 21, 2004 06:40 AM
id say switch over to the truck coils but you already got um
kp Jun 21, 2004 07:07 AM
one of the guys with PSJ mentioned there were two different truck coils, round and square, the square ones being best. I guess the round ones arent that great, I never really noticed the difference between them, may want to as PSJ for a pic of his..
parish8 Jun 21, 2004 10:03 AM
i have the square truck coils. anything else?
MYTURBOT/A Jun 21, 2004 10:18 AM
You shouldn't be having ignition problems at 13psi your problems might lie elsewhere.
What are your symptoms? What plugs are you runing and what are they gaped at?
MIGHTYMOUSE Jun 21, 2004 11:23 AM
i am THINKING about switching to moroso ultra 40 wires and the mototron coils but i havent found a way to tell if i need them or not..without just trying them. but the swap would set me back over $600
parish8 Jun 21, 2004 12:41 PM
im not, i am having troubles at 12psi and a 100shot though. i tried tr6's and now have autolite 103's at .030. i have a set of ngk br7's ordered but i dont think a colder plug will get rid of the missfire, just be a little safer is all.
symptoms.. missfire when i add in the nitrous. wide band is at 11.5 a/f ratio. misses above 5500rpm. so far i am going to try some new wires and richen it up a little.
smokinHawk Jun 21, 2004 12:55 PM
spark blow out perhaps??
Pro Stock John Jun 21, 2004 01:30 PM
Like I said before, that plug is not cold enuff for 12psi and 100 shot IMO.
I am running a set of Delco 3911's reccomended by Kurt aka 427. I'm hitting 15psi and went 136 on the 3rd shake down pass.
I am running the Melco truck coils and truck wires.
parish8 Jun 21, 2004 01:58 PM
that is why i am going with some br7's as soon as they show. would a plug that is too hot cause missing like i am seeing?
Pro Stock John Jun 21, 2004 02:00 PM
Maybe, and maybe too big of a plug gap, what were you using?
parish8 Jun 21, 2004 02:04 PM
.030
what do you think? go less?
Pro Stock John Jun 21, 2004 02:28 PM
I like these Delco plugs. NGK's are hard for me to get, and some say they foul out faster. I"m running like a .030 gap right now
MIGHTYMOUSE Jun 21, 2004 04:31 PM
havent had any fouling or wide open misfires on my tr-6's gapped at .035..... and been 138.86 :D i wouldnt say they are too hot for the horsepower.. people with more than me are running them without issue either.
Pro Stock John Jun 21, 2004 04:36 PM
These Delcos are like TR8's.
It's easy to change plugs on a truck, maybe try different gaps.
MYTURBOT/A Jun 21, 2004 06:41 PM
is it missing on a specific cylinder or is it random? you might have a weak coil or coils.
libertine1015 Jun 21, 2004 07:54 PM
Anybody got a part number on the square truck coils??
parish8 Jun 21, 2004 08:19 PM
est t
i have my missfire test turned off, the cam set off a check engine light and shut off my lock up. i will try the wires, br7's and a little more fuel. if there is any sign of missfire after that i will turn that test back on and see if i can narrow it down.
the truck almost stops acelerating like there isn't enuff power to push it past 80mph, that would have to be several cylinders to cause that.
TApimp Jun 22, 2004 09:08 AM
try an NGK 5671A-7 or -8 in there. They are a colder plug and it has a recesed tip so no chance of blowing the spark out
Pro Stock John Jun 22, 2004 10:27 AM
With my car and the FAST, the car would not pull thru 4500-5000 with the car coils on one street blast.
I have the Melco truck coils now and it's pulling clean to 7000.
I am not familiar with the NGK part number you are saying, my 3911's are similar to TR8's per Kurt Urban.
© 2026 MH Sub I, LLC dba Internet Brands
