lm7+p1sc=600 rwhp ?
lm7+p1sc=600 rwhp ?
recently bought a gen3 lm7 with gen4 crank rods+flattop pistons compcam 223/230 610/572 115+2 pac 1218 springs arp rod/headstuds 317 heads and ls9 gaskets ls7 lifters/ls2 chain. thinking of using holley hp efi and a stock ls6 intake t/b with 60lb injectors may have to use tight tuck headers in my chassis could I see 600rwhp with a p1sc
There are a lot of variables involved in a build like this so its hard to quote what it will make. The blower should be able to get you to 600rwhp assuming everthing else in the setup works out. You also should consider upgrading to a dual valve spring package over the PAC1218s for this particular setup.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Yes the PAC 1218s are rated to .600 lift so just make sure whoever sold you the package is correct on the camshaft specs as well. I believe you listed the intake valve lift at .610. Stepping up to a dual .650/.660 dual spring setup is what I would recommend.
__________________
yeah making 620 wheel with a t56 and 9inch . Mines making the 620 at 6500 rpms with stock heads and cam. ls6 intake , pushrods and springs from btr. Making 11-12 lbs on 93 with water meth . So yes you can make it out of a p1sc-1 .
LS1Tech Sponsor
There is no reason why you can't get 600 rwhp with a P-1SC, it just takes the right cam and heads, and you should get there. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
