Any mid-level power guys (750-800rwhp) using a Th350?
#41
Car is 3750 with me in it. I have myself to blame, at least partly...for the lame launches. I'm leaving not to far above idle, scared to break the rear end again (will remedy this next year). But a agree, even with the bog...it should recover quickly and light off this smallish turbo, and I suspect that this tune is the other party to blame here in addition to myself. I think the timing is soft across the board, causing it to take longer to recover. Now on the street, it's a completely different story....spools quick and is very lively...but of course there's no vht on the street either.
That's a lot of weight to move, speed/et calc says that's a 1000hp to move 3750 to 150MPH. Almost same power it says to move my 250lb heavier car to 145MPH. I don't see even the billet 7875 hitting that number.
#42
Whats quick? I see positive pressure low as 2100RPM. Little turbo is almost like the LSA blower I had, touch the gas and its in boost.
#44
#47
Originally Posted by Game ova
I'm using E85. Built bottom end.
Now that you're steering towards an automatic that is.
#49
Eh, I dunno. That would open up a whole new can of worms, as in moving the radiator...as well as new exhaust. I'm thinking this single 3 inch would turn into a rev limiter. I also still don't have a welding machine to make it all happen either....or the cash. So with that said...it's gonna be a while.
#50
I can't help but to agree. I'm sure this tune is holding me back quite a bit. But over the past several months, I've spent quite a bit of money on the car. Rebuilt the motor, new turbo, tires all the way around, and some other things I'm sure I'm forgetting. It will come through.
