2016 WCF Qualifier video with data overlay; 7.12/194mph
Here's a video I put together quickly for our 4th qualifier at the 2016 World Cup Finals at MIR with a data overlay. Obviously can't put all the data out there but some of it makes for interesting video.
Patience haha
Being able to see the tree helps me a lot, looking for the top bulb to turn off means its moving. Syncing is the hardest part of putting the data on the video
It's got an RPM TH400 (still a 3 speed) 1.86 First gear with a 3.70 in the rear
You should have seen the data from the run against the Bruders.... commanded boost, TPS, timing and RPM all over the place when he was trying to pedal it to get it to come down.
Definately learned some stuff about bringing power in quicker the final run of the weekend.
Had all the boost in by .9 seconds and more timing than normally have in it.
Went 1.10 60' and 3.08 to the 330' (on the rear tires)
Its somewhere between 8-12% at 8900 coming through the traps at 194. At least that's the estimated calulation done by BS3.
Isn't an exact number but close. PTC Bolt together converter.
