Holley or Edelbrock Throttle Body
Old Jan 2, 2017 | 08:39 PM
kward's Avatar
Default Holley or Edelbrock Throttle Body
Anyone have experience with either of these throttle bodies, Holley 112-576 90mm LS1 or Edelbrock 8624 90mm? I have the Holley but it is an LS2 and according to Edelbrock I will have to enlarge to bottom holes to allow it to bolt on. I can buy the Edelbrock but not sure if the Holley is a better TB or are they about the same on a boosted application. Just trying to make sure its worth the effort if I drill it out.
Old Jan 2, 2017 | 10:05 PM
customblackbird's Avatar
Neither are needed in a boosted application. People run stock TBs in very high power applications. Same reason why the stock unported heads can make so much power. Your cramming so much atmosphere it's not really a restriction. Stocker or ported stocker as they also provide the best idle and low rpm. How much power u trying to make?
Old Jan 2, 2017 | 10:54 PM
scottywheels's Avatar
I run a Holley 90... its a great piece and I make close to 1400 rear wheel on single 88mm with it..
Old Jan 2, 2017 | 11:16 PM
kward's Avatar
Around 850-900 really was just wondering if each would tune and idle similarly or is one better than the other.
Old Jan 3, 2017 | 11:49 AM
forcd ind's Avatar
I have the 90 mm Edelbrock, its a nice piece-even has the screw up top to let in a little more air if you want. I use the Edelbrock 90 deg adapter on a 4150 intake.
I don't remember the part #, but its a 90 mm, black
