Where to get Chain drive when i upgrade to F1R
Old 06-23-2004, 07:48 PM
U-Luze's Avatar
Default Where to get Chain drive when i upgrade to F1R
Just like title says im wanting to convert to a chain drive for piece of mind. I think i may have had belt slippage, i found some black powder remenents on the backet when i cleaned all the parts up when i took it all apart. Do i need to get then machined or call procharger and get them when i upgrade? Justin
Old 06-23-2004, 08:26 PM
NA$TY-TA's Avatar
Is that Scott's old car??? i was just wondering if you really were seeing belt slip..... there will always be some dust...... if theres a ton of it and you see your boost slipping you have a problem..... if not why do it....
Kyle
Old 06-23-2004, 08:53 PM
U-Luze's Avatar
The car would only make 7 lbs max Rob Raymer confirmed that. I call up procharger and gave them the pulley sizes and its was spinning at 67,000. 70,000 is the max on that blower. So it wasnot makeing boost for some reason and the BOV was closeing so something had to have been slipping. Im just wanting to do this for peice of mind.
Old 06-23-2004, 10:11 PM
qqwqeqwrqwqtq's Avatar
Last year at World Ford Challenge I saw alot of cars with chain drives, and alot of cars with broken chain drives.
Most of the big blower cars I saw at WFC this year had big cog setups.
I'm not sure what the best solution would be, just noting my observation.
Old 06-23-2004, 10:14 PM
frcefed98's Avatar
I got a set of cogs for sale for a D1-SC Rather attempt that then a chain drive.
J
Old 06-24-2004, 06:00 AM
smokinHawk's Avatar
isnt a COGs more rediaily available, id probably steer that route.
Old 06-24-2004, 07:25 AM
427's Avatar
The chain will not be reliable. You cannot road drive a chain. A 8mm X 50mm cog drive should drive your blower with no problems.
Kurt
Old 06-24-2004, 11:15 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
Kurt, ideally you would do cogs over 12 rib? I know someone who did a 10 rib but it sounded like the belt selection was limited.
Old 06-24-2004, 11:25 AM
Y2K_WS6_T/A's Avatar
Chain drives like to rip stuff up when they break, but then again so do belts on some occasions. Isn't there a reverse chain drive Procharger also? Is that a F2? F3?
Mir
Old 06-24-2004, 11:59 AM
427's Avatar
12 rib should be fine.
Kurt
Old 06-24-2004, 12:29 PM
Grasshopper's Avatar
ATI sells chain drive stuff, but by nature of the setup, chain drives aren't very reliable.
Old 06-24-2004, 12:39 PM
LS1Tech Co-Founder
My radiator is raked forward a bit since I removed the stock airbox. I can fit a 12 rib no problem. I think I might go 12 rib when I upgrade to the YSi later this summer.
Old 06-24-2004, 12:40 PM
BIGBOS's Avatar
I think SDCE can make 12 rib setups, that w/their spring tensioner in my mind would be the ultimate belt setup....
SD's stuff actually works........
Old 06-24-2004, 12:54 PM
eviltwins's Avatar
Buddy of mine broke the chain drive on his car, and it was messy as hell. Blower shaft is bent, tore a hole in the carbon fiber hood, busted up the water pump and oil pump, and tore a bunch of lines to ****. Atleast when a belt brakes it'll just flop around like a fish, not be a swinging metal piece of death.
Old 06-24-2004, 04:47 PM
U-Luze's Avatar
Sounds like i need to stick to the belt. I may just try to crank down the belt to see if it is slipping when i get it back togther next week hopefully.
Old 06-24-2004, 04:52 PM
BIGBOS's Avatar
The slipping dust usually shows up right around the blower pulley and it will be all over the blower, having minor dust on the standoffs is normal.......as long as its a light dusting its all good...
Quick Reply: Where to get Chain drive when i upgrade to F1R
