LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Turbo LsX 300zx Build (Sloppy Build) (https://ls1tech.com/forums/forced-induction/1856691-turbo-lsx-300zx-build-sloppy-build.html)
300LsZ 01-09-2017 03:10 AM
Ive been looking at a lot of turbo 5.3 builds on here and finally got to a start of my own. I am nowhere near a mechanic I've done my fair share of mechanical work on my Z, but I am no professional. BUUTTT this project will be a DIY kind of job. This will be a fun, street car that won't get smacked by these BMWs out in LA aha. With that being said I'd like to be around 500 hp.
Build List
Engine
  • Junkyard 5.3 (Unknown Miles)
  • Ls1 Intake Manifold (hood clearance)
  • Truck Accessories (if I can make it fit) or Fbody Accessories
  • PAC 1218 Valve Springs
  • Ls7 Lifters (Just for replacing the pitted old ones)
  • Ls9 Headgaskets
  • eBay Procomp Gen III Headstuds
Swap Components
  • Loj Wiring Harness
  • Summit Weld In Motor Mounts (refuse to pay 300 bucks for motor mounts plus this will be fun to make)
  • Loj Trans Adapter (Keep my z32 transmission they hold up to 700 ft lbs same trans as r32)
Turbo
300LsZ 01-09-2017 03:16 AM
https://cimg0.ibsrv.net/gimg/ls1tech...45112aca90.jpg
https://cimg1.ibsrv.net/gimg/ls1tech...1bd8ac3414.jpg
https://cimg2.ibsrv.net/gimg/ls1tech...a958357c45.jpg
https://cimg3.ibsrv.net/gimg/ls1tech...77afda3c29.jpg
https://cimg4.ibsrv.net/gimg/ls1tech...41dd3d0e48.jpg
GT45 eBay 69mm turbo
Wyntonm 60mm Wastegate
Columbia River 2.5" aluminized steel kit
hks ssqv bov
eBay 3" intercooler kit and piping
aem tru boost controller
Fuel
  • walboro 450
  • ebay fuel rails
  • 80 lb siemen deka Injectors
  • 1:1 Boost Fpr
300LsZ 01-09-2017 03:24 AM
Some pics of the car this will be going in. Was my first car I ever bought. I've put some much time and money into this car I only deserve to go fast aha.https://cimg7.ibsrv.net/gimg/ls1tech...c09dcae22.jpeg
https://cimg8.ibsrv.net/gimg/ls1tech...da5850ae2.jpeg
My goals would be to boost around 5-10 psi on a 5# spring nothing big just want some kick and turbo spooling! If there's anything I've missed that you feel I should add to my parts list lmk or if there's anything not needed. I also just popped the heads open and the cylinder walls were pretty damn rusted so I intend on sending it to the machine shop to get the cylinders bored and honed ( only 15 bucks a cylinder).is this a good idea? Or no
drecpt83 01-09-2017 04:26 PM
Looks like a fun project!! My engine was pretty nasty inside when I got it so I sent it to the machine shop for a hot tank, cylinder honing, all new bearings and rings and had the crank polished. Nothing special. If you're already breaking it down, take a look at everything and replace what needs to get replaced and reassemble
turbohf 01-10-2017 12:52 AM
all my cylinders where rusty. dropped the ball hone down them real quick and they where cleaned up all minty again.
300LsZ 01-10-2017 01:10 AM
How much did you end up paying for all that? and yeah so far I noticed the lifters are pitted so I hope the cam isn't pitted as well. I will be disassembling the whole bottem end tomorrow will have pics.
drecpt83 01-10-2017 11:13 AM
It was a little over $300 parts and labor. New cam bearings, hot tank, hone, king main and rod bearings, hastings rings. Then I had them do a 3 angle valve job and resurface on my heads and they tossed my btr 660" springs on for $150. My motor was pretty nasty inside, that's the only reason I did all that. still not a bad price considering I got the engine for free lol
roastin240 01-11-2017 09:32 AM
Sounds like your way ahead of the game financially on this build. I dig it man. I am wrapping up my 84 300zx "Z31" 5.3 turbo swap right now...my project escalated into a full forged 5.3 w/ 243 heads, twin disc, built t56, megasquirt, custom everything suspension and brakes...so it is taking multiple years longer than originally planned. Keep up the good work!
300LsZ 01-11-2017 11:01 AM
Ive got a lot of info and advice from a lot of your posts and threads actually! I cant wait to see the final results for the z31!
300LsZ 01-12-2017 11:55 AM
Quick question. Ive read up and seen a lot of guys that don't open up the bottom end at all and make well ove 500 hp. If I can do that I would love to because honestly why machine a junkyard block when I can just run it and get another block (maybe even a gen 4 block) to replace it easily. Now I did remove the heads and discovered the cylinder walls were a bit rusted and had some water in them, would you guys say disassembling this block fully and getting the block hot tanked, bored, and honed would be unnecessary?
roastin240 01-12-2017 05:35 PM
For a purely budget engine, I would disassemble, dingle ball the cylinders with some WD-40 to remove the surface rust...hopefully it is just surface rust and no pitting of the cylinders is present. Do as little dingle ball honing as possible, make sure to get a consistent cross-hatch pattern by moving at a contuous speed up and down. Remember that every time you go up and down, the middle of the cylinder gets honed twice and the tops and bottoms only once, so what ened up happening is the cylinders can get egg shaped if you get too crazy with it. I would then use a cylinder bore gauge to measure the diameter, taper, and roundness and determine if you can move forward with factory pistons. i would also use a micrometer on the factory pistons and make sure those are good. then I would remove the factory rings if they are not all rusted into the pistons, and file the ring end gaps to be larger...clean everything real well including piston ring grooves, install everything back exactly where it came from and put it back together. This process is pretty common for a high power stock bottom end build. I would at least pop a piston out and make sure the rings are moving freely and not rusted. Word of advice, be VERY careful with the connecting rod interfaces...they are "cracked" rods and fit together like a microscopic puzzle piece....remove gently and install them back together very gently and slowly snug back together....this will give you a chance to inspect the rod bearings and rod journals as well. If they look good, then reuse the bearings. Hope this helps out!
300LsZ 01-14-2017 03:42 PM
https://cimg8.ibsrv.net/gimg/ls1tech...5b4beb1fcf.jpg
https://cimg9.ibsrv.net/gimg/ls1tech...cc4fcfc498.jpg
300LsZ 01-14-2017 03:43 PM
A few more pics of the madness before it gets stripped down and taken to the machine shop for hot tanking...should I get it honed as well? And what is this orange crap on the lifter hole?
drecpt83 01-14-2017 05:25 PM
If you're not comfortable doing it yourself, let the machine shop do it. Its not a hard process at all but, if you do it wrong you'll make it an oil burner. Are you going to run the stock cam? Lots of guys run engines straight from the junkyard without opening them up. I personally wouldn't , without at least taking a look to see if anything was out of the "norm". The stock parts will handle the power no doubt but That's alot of work just to possibly find out that an engine is knocking or something. Doesnt hurt to take a peak and if all is good, apply boost and have fun lol.. As for the lifter bores I can't really tell what that is from the pic. Rust?? Cylinders definitely needs some attention but If it's going to the machine shop let them have at it
drecpt83 01-14-2017 05:32 PM
Roastin240 gave excellent advice if you're willing to do the work yourself
300LsZ 01-14-2017 07:17 PM
I am going to take it to the machine shop I just want to know what I need to pay for it's a budget build so I don't want to start spend money (that I don't have) on unnecessary things. I would like a fresh block to start from though, I don't want to do two pulls and blow it up.
300LsZ 01-21-2017 09:25 PM
Tore down the block a bit more to check out the rod bearings and pistons. It all looks nice just two rods had some side to side play but no worries new rod and cam bearings on the way. Sending it off to the machine shop Thursday for a bath and hone. Any one have a ls1 intake manifold for under $200? Ahahttps://cimg2.ibsrv.net/gimg/ls1tech...f6a8ef4ce8.jpghttps://cimg3.ibsrv.net/gimg/ls1tech...0b1811e198.jpg
300LsZ 01-21-2017 09:53 PM
What they use to look like...https://cimg8.ibsrv.net/gimg/ls1tech...2078e0266e.jpg
300LsZ 02-17-2017 09:49 PM
Got to order some parts:
GT45 69mm Turbo
2.5 Intercooler Kit
2.5 t4 divided flange
2.5 mild steel mandrel bend
2.5 Flex Pipe
2.5 vbands
https://cimg4.ibsrv.net/gimg/ls1tech...288b1e2030.png
https://cimg0.ibsrv.net/gimg/ls1tech...04646d94d.jpeg
https://cimg1.ibsrv.net/gimg/ls1tech...11a2752ec.jpeg
https://cimg2.ibsrv.net/gimg/ls1tech...be8362abe.jpeg
https://cimg3.ibsrv.net/gimg/ls1tech...d7e8ee935.jpeg
https://cimg4.ibsrv.net/gimg/ls1tech...6d7851569.jpeg
https://cimg5.ibsrv.net/gimg/ls1tech...7ebb91e9c.jpeg
https://cimg6.ibsrv.net/gimg/ls1tech...9883b267dd.png
300LsZ 02-17-2017 09:56 PM
Also ordered:
Rod Bearings
Cam Bearings
Main Bearings
Piston Rings
https://cimg7.ibsrv.net/gimg/ls1tech...872535a616.jpg
https://cimg4.ibsrv.net/gimg/ls1tech...63263c60a3.png
© 2024 MH Sub I, LLC dba Internet Brands
