T6 or twin T4 for 1000 rwhp
Go to car, open hood. Look under it...is there room for two turbos or one ? Which will fit easiest ?
There ya go, that choice is made.
LS1Tech Sponsor
I find the twins package a little nicer than a big T6. They take up less space between the engine and radiator. I prefer installation of twins as there is no dealing with a crossover pipe. Also smaller T4's come in at about 20-25lbs each opposed to roughly 50lbs for a single BW, so weight of the turbos is essentially a wash. Both kits use 2 wastegates with the divided crossover in the T6 kit to use the benefits of the twin scroll. Both kits use 2 BOVs. Hot-side piping is less in a twin kit with 2 short up-pipes opposed to a longer crossover. Comparing 2 smaller 3" downpipes for weight opposed to a bigger 4" or 5" downpipe will come close to a wash as well.
For pricing and weight, both kits are extremely similar.
I am a twin guy at heart so I would run that myself, plus you have far more turbo options, however with our new V3 designs of both the Twin and the T6 kit you cannot go wrong with either, both are awesome!!
Jon
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
Quite close but not exact. If you want to run them into a set of true duals for example, it would be very easy to fab a pipe once installed to mate to the duals!
__________________
LS1Tech Sponsor
haha, once you get all of the piping in there you will be happy all that A/C crap is gone!
__________________
I'm in the process of running twins with a true dual setup(bullet straight thru muffler)similar to this. Going twin S366 now with the same goal of 1000+whp, while trying to maintain a sleeper appearance. I previously had a large single T6 on this car with a 4" dp ran down where the a/c was originally. Sacrificed ground clearance a bit trying to run 4" exhaust all the way out back, then y into 3" duals for the same sleeper look
