Turbo oil feed... another one
I have an aftermarket pan on my LM7. No chance of using the spot above the factory oil filter. Now thats out of the way.
I was considering tapping into the pressure sensor behind the intake manifold. is my research correct, when i say i need a m16x1.5 thread adapter to my turbo line size? Is there a way i can "T" there so i can actual get an aftermarket oil pressure gauge?
What i am asking is, can i run the adapter, put a T in so i can use it for my turbo line and my oil pressure gauge?
Which adapter do you have in mind?
