My 98 z28 turbo build thread
#41
Time has left this thing pretty ragged looking , time to start wire wheeling and bringing it back to life!
Cleaning this thing up and making it shine again is gonna take some serious effort . All the little crevices etc are a pita to get into but when it's done it'll look better than the day it rolled off the floor.
So over the weekend I finally sold my previous turbo setup , now it's time to make a decision transmission wise . Pretty sure I'm gonna play some Russian roulette and go with a hawks stage 3 rebuild kit . Some say you'll never get a t56 to withstand that power , and others claim they've done it on a stock transmission! My main concern is figuring out a way to have bungs and sprayers in this. I believe that'll help keep the transmission upto the task of the new power it will be tasked to handle . Gonna start to disassemble it tomorrow morning first thing. Lots of pics to come
#43
It's been a minute but with the twin turbo kit shipping out yesterday,, it's time to start kicking it into high gear around here. Got the main hoop installed in the car today, as well as the twin fuel pump mounted in . Just need to hook my lines up, drill the bulkhead and run my new wires through.
Main hoop of the 8.50 Wolfe racecraft cage installed
Fuel pump assembly modded for the twin 340s. It's hard for me to break every little thing down. When I get moving at the shop
I tend to not stop till whatever I'm working on is wrapped up. Big shoutout too scottybg and his fuel system write up. Essentially without his thread I'd be sending this too my buddies to be installed 👍🏼👍🏼
#45
This arrived today, man I can't get over the quality and craftsmanship of the new v3 twin kit.awaiting the motor to arrive back from the machine shop and then the installation process begins. If you're on the fence about your turbo build, shoot Jon or Casey a message on here and they'll set you up great!
#46
Not a 98 z28 build anymore!
I abandoned the camaro mid flight , anyways I'm within a week of finishing my 2004 gto twin turbo build! The rotating assembly and block I was using for the camaro build found its way into the gto . Anyways I'm gonna post up a bunch of pictures and keep updating as I finish this thing up in a week or two .
Twin s366's
Bare lq4 block fresh from machine shop
Battery relocated to trunk
A few parts
Watt 102'm throttle body
New cam bearings
King racing mains and crank install
Doing it old school. Whatever works!
Wiseco -11cc dish pistons
Ati super damper with ac pulley
Ls9 mls head gaskets
Arp head studs
243 heads from ls2 gto
Holley sniper 102mm intake
Dropping the motor and trans in
Shiny and pretty!
Welded the cast manifold to stainless 16 gauge piping
Turbo playing peek a bo behind the headlight housing 👌
A few parts
New cam bearings
Arp head studs
Shiny and pretty!
