Notices
Has anyone run a t4 s480 on a Huron speed ac kit
Old 03-07-2017, 01:19 PM
s25hanh's Avatar
Im currently putting a s484 in my V2 AC kit..... There is no way to fit that big of a turbo in there without modifying your rad support. Honestly kind of wish I went with an "average" size turbo like everyone else (75-80mm).
My plan is to mod my rad support like necrocannibal did. Also going use two Derale pusher fans. Running an LT1 radiator and stock AC condensor.
Also if it matters- running the front bumper exit exhaust. Which has to be modified as well to fit the biggest exhaust flange on the turbo.
Keep us updated fastcars95!
s25hanh is offline
Old 03-07-2017, 01:20 PM
s25hanh's Avatar
Originally Posted by KyleLanter View Post
I trimmed about an inch off the locating rod on the radator. Also trimmed the same amount of the rubber isolator that goes around the plastic locating rod. Other than that everything is as it was stock.
happen to have pics man?
s25hanh is offline
Old 03-07-2017, 03:12 PM
ScottyBG's Avatar
I'm not sure what he is referring to? I have no locating rods? The bottom sits on a rubber grommet on the drain side, and a rubber U on the other. The top is only held by the cover that bolted to the support and uses 2 rubber u shaped mounts to locate the top.
I think what compressor cover used makes a big difference. I've considered cutting my T4 flange off and welding on a T6 in its place. Since the same turbo is about $250 less in a T6 version. And why choke it to a T4 anyhow? I can buy a T6 flange for about $40, so I save about $210. I think as long as I don't use one of the v2 race covers it will fit. But that is a project for next year. Looking at the drawings, the S400 series with the standard cover only needs about another 1/2 of clearance vs the T series I have, on the radiator side. The compressor cover outer dimensions are basically 9 1/2" vs 8 1/2 inches. The turbine side is moot, because the compressor is the limiting factor.
ScottyBG is offline
Old 03-07-2017, 04:11 PM
KyleLanter's Avatar
Here's a few I just took of you guys want other angles just let me know
KyleLanter is offline
Old 03-07-2017, 04:30 PM
When you moved the radiator forward a 1/2"....did the factory condensor fit perfectly?
I need to move my radiator forward 2 inches to fit the S485 with V2 race cover. But I'm wondering what happens to the condensor......then pusher fans in the front.....??
LS6427 is offline
Old 03-07-2017, 04:34 PM
Originally Posted by necrocannibal View Post
I'm running a full exhaust with a cut out dumped right off of the turbo.
Thats exactly what I want to do.....full exhaust and a cut-out off the turbo pointing straight down to the ground.
Do you have pics of your exhaust set up from off the turbo going back to where a "Y" pipe would be?
LS6427 is offline
Old 03-07-2017, 04:36 PM
Originally Posted by SteenH View Post
The rad will have to be moved quite abit, and if you'd like to keep the A/C that may require some fiddling with.
I'm running a t4 s475 on a Huron non AC v2, though I'm running a stand up griffin rad. I don't have a whole lot of room between the exhaust housing and the rad, even with it flush to the rad support. The car is a storage shelf right now, but I can try and snap some pictures of where the turbo sits if you'd like.
I can't see there being much of a difference in turbo location from the non-ac to the ac kit, but I've been wrong before.
If an LT1 radiator is stood up vertical, will the condensor and pusher fans fit in the front still?
LS6427 is offline
Old 03-07-2017, 04:44 PM
KyleLanter's Avatar
My condenser and lines would work but I am not sure that at 2" the factory lines would reach. Huron sells a ac lines kit that solves that problem.
Old 03-07-2017, 04:48 PM
But will the condensor and Deral pusher fans fit....if I moved moved the radiator 2 inches forward or all the way vertical...?
I want to do this......but with the smaller LT1 radiator.
https://ls1tech.com/forums/forced-in...ow-part-s.html
LS6427 is offline
Old 03-07-2017, 04:54 PM
KyleLanter's Avatar
The upper rad support will need notched on the underside where it is not visible for the upper Pusher fan if you were on 12 inch or larger fans as I did because you have to stagger them. I did not need to Notch my support because my fans are still about an 8th inch away
Old 03-07-2017, 04:56 PM
KyleLanter's Avatar
Here's a picture
Old 03-07-2017, 04:57 PM
  #32
Do you happen to have a picture of your pusher fans mounted to the front of the condensor?
LS6427 is offline
Old 03-07-2017, 04:59 PM
  #33
Here's a picture
Cool...you read my mind.
Ok. so I may have to cut away some of that support so the fan motor will clear it....
LS6427 is offline
Old 03-07-2017, 05:01 PM
  #34
KyleLanter's Avatar
Here is how they were mounted angle wise on the condenser unfortunately the only picture I have is on the radiator because after I assembled everything I deceived to ditch the ac
  #35
Another thing we are making is a custom sheet metal shroud.....so the entire surface of the condensor will get air blasted through it by the pusher fans. The shroud will keep the fans away from the condensor surface about 1/4"-1/2".....
LS6427 is offline
Old 03-07-2017, 05:05 PM
  #36
KyleLanter's Avatar
You'll need to notch your upper or lower rad support to allow room then
  #37
Those are the Deral pusher kit from Huron Speed?
LS6427 is offline
Old 03-07-2017, 05:08 PM
  #38
KyleLanter's Avatar
They are the derale 16925 pushers I ordered from summit
Old 03-07-2017, 05:09 PM
  #39
Ok...thanks for the pics and info.
LS6427 is offline
Old 03-07-2017, 05:10 PM
  #40
KyleLanter's Avatar
Anytime man
Quick Reply: Has anyone run a t4 s480 on a Huron speed ac kit
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
