72 Lemans with 5.3 and ChinEasy T76
lets see how long this Chinese turbo will last! only at 5psi while I shake it down and make sure everything is G2G...and its borderline scary now! Once I get all problems taken care of (knock on wood cause I haven't found any yet) I will dyno tune it at 10-12psi for daily street driving, and still run the A/C...well I hope.
Did the LS sway about 5 years ago thanks to Clays Customs in Las Vegas. Decided to try my hand at fabing up a turbo kit and with the help of Hood Fabrications (tig welded all the hot and cold piping) also here in LV, this it what I came up with.
Price list
Turbo Build
Silicone intake adapter 4-2.5 $20 ebay
Blow off valve $50 ebay
Intercooler pipe kit $107 ebay
FMIC $60 CL
Chinese T76 Turbo $270 ebay
Turbo blanket $30 ebay
Turbo oil lines (-6 90, -6 str8, 6 SB line, -10 45, 3 -10 SB line, 90deg drain bung) $100
Oil inlet flange $10 ebay
Oil outlet flange $13 ebay
Oil supply cap $10 ebay
50mm Wastegate $95 ebay
1 7/8 ubend for WG $20 ebay
2.5 Exhaust pipe kit $140 Speedway Motors
2.5 vband clamp/flanges x 4 $60 ebay
3 Vband clamp/flanges $17 ebay
2.5-3 reducer $29 ebay
Turbo manifolds (modded truck) $50 CL
O2 bungs x 2 $10 ebay
2.5 6 flex pipe $23 ebay
2.5 4 flex pipe $14 ebay
2.5 Flowmaster muffler $88 ebay
Thermal wrap x 3 $75 ebay
2 Bar On3 MAP sensor $34 On3 performance
NGK TR6 spark plugs x 8 $17 ebay
Boost gage $25 ebay
60lbs SD injectors $320 ebay
T4 turbo flange $23 ebay
Exhaust studs for turbo flange $20 ebay
ECM reprogramming $150 ebay (Erk mail order base turbo tune)
1/8 NPT brass 90 $5 ebay
Silicone pressure line $10 ebay
Spark plug wire blankets $20 ebay
Total $1915
Prep for turbo install
Re rout water lines $20, Re rout tranny cooling lines $10, Re rout power steering lines $50
LS swap info
LS 5.3/4L60E/re-worked truck harness with LS1 intake (200k miles)
Holly oil pan
Aluminum radiator
Lincoln Mark 8 fan
Tanks Inc sumped gas tank
Walbro 255 intank pump with corvette reg/filter
FMIC $60 CL
Boost gage $25 ebay
Total $1915
LS swap info
Holly oil pan
Aluminum radiator
Lincoln Mark 8 fan
forgot to mention that i'm upgrading the tranny (thinking about a performabuilt 4l60E stage 3) and beefing up the drive shaft and rear end before it hits the dyno. my goal is to stay between 550-600 rwh and keep it off the track.
