VSRacing T4 1.25ar 80mm Billet 96x88
Just saw where this turbo will be available at the end of this month through VSRacing. Who's going to be the first to give this turbo a shot? I bet this thing would work really well bolted up to the Huron Speed new V3 turbo kit.
LS1Tech Sponsor
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Figure 200ish for the housing plus machining and markup. Seems about right. T4 housings are usually a $200 option without machining form other vendors.
I’ve had both and I’d never run a T4 with an auto/LS combo. Even a mild 4.8 spools a 1.32 T6 S480 plenty quick if setup properly. (no trans brake even) Suppose I could see it on a manual build… With a little effort you can weld a 4 Vband on the T6 and it's not much harder to package. I was launching at 8lbs with no 2 step or trans brake, and ramping up to 20lbs faster than my tires would handle. Had to dumb it down to hook a 30" MT drag radial with 3.25 gears... And that's with a 1.80 glide.
Connection kit, on the coldside ? I will be running S485 on my V2 T4 HSP kit.
Vs t4 96x88 on sale
I know this is an older thread, but i am interested to know if anyone has pulled the trigger on one of these yet ?
Well, other than me.......mine is scheduled to be here tomorrow. They are on sale for 875 bucks, shipped free.
Mine is going on a sbe LS3 with hand ported 317s, bullet turbo grind cam, holley single plane, and fitech tbi. 95% street car, 3400 lbs, 2004r with all the billet parts, 3400ish billet stage 5 revmax converter, 3.42s.
Only looking to run 12-14 lbs on pump gas, 31x12x4 a to a cooler and twin nozzle 50/50 water meth. Just a street toy (72 camaro), so i dont expect i will be much help on results
.with this unit.
anyone else done anything with it ?
.with this unit.
Good to hear. 156 mph is strollin ! I know i would be better off with a t6 turbine housing with the cubes , but the way my piping and frontend stiffening bars are laid out, i just dont have room. I dont suspect i will choke up too bad though with my low boost goals. Plan to shift it around 6500 or a little less.
