Straight thru bullet muffler, how close can I get off the turbine?
as the title says, im running an up pipe thru hood and have a 9" bullet style muffler but im not sure how close is too close. the softening point of fiberglass is like 1600f and melting is around 2200 according to google.. its gonna be driven on the street here and there so i wanna run this muffler but im limited on room, heres kinda what im working with its a pretty long pipe for under hood but its gonna be in one if the straight sections obviously ..
my buddy has a similar length downpipe and did a before and after and the small muffler actually makes a huge difference, although its still loud its not nearly as bad.
Ive read that these straight thru mufflers actually improve flow to an extent so im not too worried about that i just dont no how close you can get to the outlet before egt's are an issue... couldnt find much on it with a quick search...
i guess my buddy has been running his about 16" from the outlet for about 1000miles, dont really no why i asked in the first place lol i guess it was something to discuss..
Anyways im just gonna run it, i think it will work out good.. thanks guys.
It wouldn't be an issue to put it right after the turbine. Before the turbine is where exhaust gas is really hot and the temperature drops quite a bit when it's no longer compressed. It's not much different than having it at the end of a header collector on a non-turbo application.
Isn't that a Dynamax Mini Race Bullet?
Those don't have ANY packing.
https://www.summitracing.com/parts/wlk-24250/overview/
In that case, I might just put it right off the housing because thats where i have plenty of room.
maybe ill post a video up when its done, don't know if it will put the noise level into perspective in video but it might..
