Huron Speed Branded Billet 78/75?
As the thread title states, I see that Huron Speed has a Huron Speed branded billet 78/75 turbo for sale for $699.99 with a 1 year warranty. I've been interested in upgrading from the TC78 with a turbo that doesn't take up a lot more space and won't have the wife wondering why I spent over a grand for a "different" turbo.
I don't know if this is comparable to other company's Billet 7875 offerings and if you are paying a bit more for the 1 year warranty or if it's of better quality and the warranty is a bonus.
http://shop.huronspeedproducts.com/H...er-hst7875.htm
Thoughts?
Thoughts?
I like that Huron is willing to literally put their name on them and of course, I like the warranty. I'm wondering if they are different than similar offerings by other companies that cost a bit less.
LS1Tech Sponsor
Billet 78mm compressor wheel
4" Inlet w/ 3" Outlet compressor cover in your choice of Polished or Satin
82/75 turbine wheel
T4 .96 a/r housing with 3" Exit
Journal Bearing
Full 1 year warranty
Comes with gaskets and Billet Oil Drain flange as well
Anyone interested in trying one out please contact me! These are newer however all of our initial results have been excellent and everyone that has one in their hands seems extremely happy with it as well.
On the shelf, no wait or build time at the moment as well.
Jon
82/75 turbine wheel
Journal Bearing
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
Thoughts?
Thoughts?
*Full 3" Discharge on the compressor housing, I believe what you are looking at is 2.5".
*Your choice in Polished or Satin Compressor Cover
*Included required oiling fittings to bolt right on, not having to spend more money and source more parts later
*Full 1 year warranty gives you peace of mind and the know that we stand behind the quality of the product!
*Also backed by Huron Speed customer service! We are here to help, answer any questions, etc 7 days a week, morning, noon and night, even holidays!
__________________
LS1Tech Sponsor
Compressor wheel will flow 1200, however on a 347 you can expect up to roughly 900rwhp depending on drivetrain and dyno, a little less on a 376ci.
__________________
LS1Tech Sponsor
I am sorry but I will not do that. It is a very good, solid, reliable manufacturer who we do not care to disclose so others can jump in and take advantage of. I am sure you can understand this.
__________________
I cannot comment on the others as I haven't used them, and don't know exactly which you are referring to but I have an idea. Here is info I can provide to help out in comparison based on specs:
LS1Tech Sponsor
Well obviously there is going to be some look at the unit. If you starve it or do not set it up properly, that is a different issue. Just as if you were to say your new PS4 video game isn't working in your x box. However set up properly if you have any issues we will work with you to resolve it or else replace the unit if there is an issue with it. Backed by full Huron Speed support (even on holidays such as now)
__________________
LS1Tech Sponsor
Well if you got it then it couldn't have been that bad
__________________
LS1Tech Sponsor
Of course we need to make sure the unit was not installed upside down, had oil, etc... however if there is a problem with the unit, we stand by it, will promptly work with you, and have it replaced if need be!
I know where you are coming from and understand with your question. To address what I believe you are getting at would be yes we need to do some due diligence which I am sure you understand, but we are going to be very prompt to quickly make sure the issue doesn't reside from elsewhere and then replace the unit if everything appears to be in proper order with an issue residing in the unit itself
__________________
LS1Tech Sponsor
This is our part, our warranty. You deal with us on it! Nothing to worry about. We are giving this part a warranty for you to have peace of mind and confidence when purchasing it!
Jon
Jon
__________________
