Holley Turbo Manifolds
#44
why would you only want one of the three pieces? unless you already have same type hooker headers installed 8510HKR is the PN for the set and is still running a good $450 and then the crossover is another $200
#45
Im just saying there are guys out ther charging 500 just for one side. This is cheaper. You don't necessarily need the driver side. A custom cross over can be done for those on a budget just cutting the driver side and making a merge back to passenger. I agree though 699 all in is fantastic for a hotside.
#46
#53
yes most people just run open loop speed density tunes.
i am currently copying a couple other guys here and adding back my primary narrowbands to run in closed loop at idle.
narrowbands do not have a pump cell, so they could go before the turbo but i think the heat would affect them so i'm putting them after my turbo.
#54
I can def tell you with the Holley mounts you would need to make a manifold for the DS with the stock steering box, lol-I cut out the side of a stock manifold trying to get it to fit, blew $180 bucks on another manifold I thought I could make fit, it didn't work. Kind of wish I had just reversed 2 truck manifolds and made my own system, lol
#59
$450 for his kit to make a 90 & wg setup^^^^^
I’ve found on a 1st gen fbody / 3rd gen nova, a 4th gen 98-02 fbody mani is the only one to fit with the stock steering box. It is very close but does fit. The further back the engine is, the more clearance you will have. I’m using the holly swap kit also.
I was about to buy this pass log only until a few people pointed out the lower radiator hose issue and where the turbo sits on face book. $299 with issues or for $500 + or - buy a log that has no issues and places the turbo higher and outward. I’m still debating what to do.
#60
Just got the fab work finished up installing a BW S485 using the Holley manifold kit on my '67 Camaro.
SBE L33, LJMS cam, Pro-Flo Intake
3" cold side with bungs for pre-IC temp, pressure and wastegate. LPS Alpha-Loc coupler, Vibrant 18x12x6" core with fabricated tanks
4" stainless downpipe with 4" LoudValve boost-activated cutout and dual 3" exhaust into Borla XS mufflers
Front grille shot. Had to use a narrower intercooler due to RS headlight doors swinging inward when open.
Intercooler bracket bolts to stock latch location. Going to use Quick-Latch fasteners to replace latch.
60mm VS Racing WG merged into downpipe with slip-fit connection. 3.5" cold side going to throttle body with 50mm VS Racing BOV.
I plan on coating the cold-side piping, compressor housing, and possibly the intercooler black
CNC plasma cut turbo brace
