How much can backpressure effect hp and turbo spooling?
Old 06-23-2017, 05:22 PM
  #121
imma_stocker's Avatar
Yea I'd say 200hp gain is worth diving into. Beauty of turbos, all you have to do is feed em and let em breathe.
Old 06-23-2017, 08:59 PM
  #122
lmt0705's Avatar
It's going to take some serious fab work but I think I can slice the sides of 2 4 inch pipes and mane them fit, then put a cutout any the bottom for the track then continue the dual 4 inch up to the drive shaft loop. I'm kind of screwed from there though
Old 07-13-2017, 11:16 PM
  #123
lmt0705's Avatar
Update.....Wound up squeezing in dual 4 inch downpipes with loudvalves at the bottom that open up at 2psi then merged my old dual 3 inch into them and put in a better cam for my setup. Made 1413 at 21.5 psi. Tried 25 but it blew the tires off the dyno! Backpressure is lower than boost the whole pull and my co2 usage is way lower.
Old 07-14-2017, 05:25 AM
  #124
a05c's Avatar
Glad you got it figured out. Now change the tires, and go to the track.
Old 07-19-2017, 07:50 PM
  #125
Turbo LS1 SS's Avatar
Damn that made a difference!
Old 07-19-2017, 07:55 PM
  #126
Old School Heavy
speedtigger's Avatar
How quickly does it spool now?
Old 07-19-2017, 11:01 PM
  #127
helicoil's Avatar
What was the cam choice?
Old 07-22-2017, 06:33 AM
  #128
lmt0705's Avatar
Went with a lil Jon specd cam, definitely spools faster during a pull or run now, on the street it used to take me a couple seconds to see positive pressure, now it's in boost almost immediately after going wot. Still a little slow on the street but that's probably due to being low on rpm when I hit it
Old 07-22-2017, 09:02 AM
  #129
Old School Heavy
Very nice! Turbos on the street are sooo much fun.
Quick Reply: How much can backpressure effect hp and turbo spooling?
