Project Nova - The quest for 1000hp VS s480 l33 347
Old 07-10-2017, 11:32 PM
  #41
Cwarta's Avatar
Originally Posted by Rudy72
that looks like the Global West Coil over stuff, I'm looking at their front and rear Coil over for my 72, looking at doing a similar deal with the cast hooker manifolds, or make a log type manifold with some .120 wall stuff... Do you have a support going to the frame to help hold that Turbo? Looks like a great build, keep motivating!!!
the coilovers are viking double adjustables. I'm going to tie the turbo over to the block once I have all my hoses routed etc so I can make sure it's not in the way .
Old 07-11-2017, 06:59 AM
  #42
Rudy72's Avatar
Default Quick work
Great progress on the build and transformation of the new body, nice to all the work your putting in, Great build!
Old 07-11-2017, 08:37 AM
  #43
Cwarta's Avatar
Thanks man! Appreciate the kind words!
Old 07-13-2017, 09:41 AM
  #44
Cwarta's Avatar
Exhaust flange came in today! Hotside is 99.9% done, going to wrap it today. Found that the old sbc thermo housings will bolt on, makes running the bottom hose much easier!
Then I'll be tackling this crazy nest behind the dash for my Dakota Digital swap
Old 07-13-2017, 09:53 AM
  #45
Forcefed86's Avatar
What are you doing for a thermostat with the SBC thermo housing?
Old 07-13-2017, 10:44 AM
  #46
Cwarta's Avatar
Was using an ls1 thermo with it, 'ow just a sbc thermo with a freeze plug between the hot/cold side of the pump.
Old 07-13-2017, 11:28 AM
  #47
Forcefed86's Avatar
May have to give that a whirl, thanks!
Tip on the hot wrap. Use SS safety wire. (cheap at harbor junk). Those SS zip tie deals come loose and are generally garbage at staying snug in my experience. (maybe I got a bad batch).
I like to paint mine with BBQ grill paint too. Keeps the water from soaking into the wrap and I think it helps hold heat in too.
Attached Thumbnails Project Nova - The quest for 1000hp VS s480 l33 347-wrap1.jpg
Old 07-13-2017, 11:47 AM
  #48
Cwarta's Avatar
thanks for the tip! I'll try that! The rest of my wrap cake in today so I'll finish it with ties and come back with SS wire
Old 07-13-2017, 12:49 PM
  #49
Cwarta's Avatar
Here is the setup.
Im trying to decide on a puke tank setup like I ran previously, or an expansion tank setup like factory, ran to the farthest forward heater core port on the pump, and the hotside plugged.
Any thoughts on that?
Old 07-13-2017, 03:12 PM
  #50
Forcefed86's Avatar
I have that same rotating filler neck! Does the gasket on the thermos actually seal up against something?
I’m always torn there and end up with a surge tank. I hate how they look though. Technically as long as you are at the highest point in the system you should be able to plumb the steam vent to it. I ordered this china cheapie to try on the mustang. The return on the bottom of the tank is on the small side. But it’s cheap and seems to be working. Hate how it looks thou!
http://www.ebay.com/itm/350ml-Univer...FYxhm-&vxp=mtr
The plastic VW surge/swirl tanks are also cheap.
http://www.ebay.com/itm/OEM-2003-200...NX~53b&vxp=mtr
Old 07-13-2017, 04:22 PM
  #51
Cwarta's Avatar
Thanks for those! I've been looking at a nice tig aluminum one on fleabay.
Yes the ls gasket fits perfectly in the oring grove of the swivel thermostat and seals exactly likenstock ls
Old 07-13-2017, 06:42 PM
  #52
etijsma's Avatar
I'm running that same vw coolant bottle with my LS swapped vw. Works well with no issues.
I have the bottom running to the heater core port with the other port blocked off. The port on the top of the bottle goes to a port on the highest part of my radiator.
If you go that route make sure you use a new tank and cap. I chased my tail trying find the issue of coolant seeping past the cap. Turned out that the bottle had groove down where the cap seals.
Old 07-14-2017, 06:45 PM
  #53
Cwarta's Avatar
Making progress tonight! All kinds of goodies came in!
Old 07-15-2017, 08:21 AM
  #54
rkupon1's Avatar
I ll say it again,...awesum. i luv that its all you on this build
Old 07-15-2017, 10:40 AM
  #55
Cwarta's Avatar
Thanks man! I've got a bunch more pictures to upload but gotta get better cell signal
than I do here at home to upload them
Old 07-15-2017, 11:01 AM
  #56
Cwarta's Avatar
Originally Posted by 89ROC-Z
Looking Good! What did you do with the turbo camaro?
**** man sorry, I didn't see your comment until now. I sold the roller to a good friend of mine and putting together my nova, tired of seing it sit
Old 07-15-2017, 12:22 PM
  #57
Cwarta's Avatar
Taking advantage of the cool nights, worked on this thing till 4am last night.
Old 07-16-2017, 03:26 PM
  #58
Cwarta's Avatar
My first attempt at attaching two pieces of aluminum! Not pretty but it's functional
Old 07-16-2017, 05:15 PM
  #59
stevieturbo's Avatar
Functional is all good !
Old 07-17-2017, 09:51 AM
  #60
Cwarta's Avatar
New rad/intercooler mount fabbed up and started on lower charge pipe routing
Quick Reply: Project Nova - The quest for 1000hp VS s480 l33 347
